08 street bob triple tree
Old 01-30-2009 | 03:23 PM
MyBeerBelly's Avatar
MyBeerBelly
Default 08 street bob triple tree
Hi All
So I have an 08 street bob with that intergated tree, I have done searches all afternoon to try and sort this out. Still a few questions....
If I get bars the same bar size as stock, is there going to be any issues? What is the stock street bob bar size (diameter)?
Who makes a replacement tree...what other options are there?
thaks for any help you can give
Cheers
J
Old 01-30-2009 | 03:31 PM
JRK5892's Avatar
JRK5892
there is only one place to get risers for that, other than that you will have to replace your top tree (off an 06)... harley bars are 1 in... just get 1 in bars and you will be cool
Old 01-30-2009 | 03:33 PM
fiend138's Avatar
fiend138
The sock bars are 1", there shouldn't be any problems with any other 1" bars high enough to clear the tank. As for chubby bars, some hit the top of the forks, so you might need to slide the forks down slightly in the tree's.
Old 01-30-2009 | 03:38 PM
nkauf21's Avatar
nkauf21
Either keep a 1" bar or swap your upper tree for an '06 or '07. Then you can run any riser/bar combo that you want.
Old 01-30-2009 | 04:04 PM
rounder's Avatar
rounder
you can get a 1 1/4" bar as long as the riser area is 1". Many aftermarket bars are done this way and feature internal wiring.
Old 01-30-2009 | 06:08 PM
jmpancoast's Avatar
jmpancoast
Its not so much the diameter of the bars that is the issue. Its primarily been the type of bar (limited as to what bars/risers you can use) or the position the bars put the rider in.
Old 01-30-2009 | 06:23 PM
Gwjvw's Avatar
Gwjvw
08 too i think,i almost had my stock fxdc trees sold to a guy with a bob for this same reason.
VenturaChop's Avatar
VenturaChop
you cant get just get a upper tree from an 07 or 06 well you can but it wouldnt look right. the bolt placement and design are diffrent
Old 01-30-2009 | 06:30 PM
jackyl's Avatar
jackyl
Old 01-30-2009 | 08:01 PM
bkbob08's Avatar
bkbob08
I had the same problem, replaced the tree. Then you can use whatever bars you want.
