What kind of air cleaner is this?
On my new (used) 07 FXDB it has an aftermarket air cleaner. The dealer said the previous owner added it after getting the Big Radius pipes and Stage 1 upgrade/download.
Can anyone identify it? It's also odd since it seems to have no filter behind it, like the stock ones do (at least not that I can see from the front or side). Why is that?
Forgive my ignorance as this is my first Big Twin.
looks to me sir like someone has bolted a derby cover over a stock ac cover. Take the 5 fasteners off, and you'll more than likely see a single fastener in the middle of that cover. There are a thousand different ac covers available for your setup. e bay search harley davidson air cleaner cover.
if its the standard HD football cover then my guess would be any would work. My guess is if you take all those allen bolts out of that cover there will be a star shaped pcs of metal under it that is used for that cover to attach if thats the case you have a regular football cover and should be able to by any insert cover for your year of bike and hd football
