Decisions on wheel finish.
I own a Street Bob in denim black have had various parts powdercoated black(fork lowers,triple trees,handle bars,levers,headlamp bezel,battery strap,rear fender mounts and sissy bar)and am now thinking of my next move with the wheels,they're standard chrome now but want to change the look.there are a few options and I'll start with the cheapest.
A)All black p/c
B)All black p/c but leaving the nipples chrome.
C)Black p/c hub and wheel with chrome spokes.
D)Chrome hub and spokes with black p/c rim.
Any suggestions would be welcome and if any one can add pictures of any of these wheel finishes for comparison it would be much appreciated ...
Thanks in advance Sumpnut.
A)All black p/c
keep the chrome rims and hub. Black spokes and nipples. With the spokes being the PITA to clean, black spokes will probably be easier than chrome ones. I would also recommend that you buy lyndall pads to install when you get your wheels done. Without all the brake dust, cleanup is a breeze with simple soap and water. I also think you should stick to a chrome pipe as well. Hard to tell without any pictures of you scoot though.
One more thing, do the thick spokes that are available as opposed to the standard thin ones. Looks sweet.
A)All black p/c
A)All black p/c
chrome wheels and hub. Black spokes and nipples. With the spokes being the PITA to clean, black spokes will probably be easier than chrome ones. I would also recommend that you buy lyndall pads to install when you get your wheels done. Without all the brake dust, cleanup is a breeze with simple soap and water. I also think you should stick to a chrome pipe as well. Hard to tell without any pictures of you scoot though.
your bike is a perfect chrome to black mix. Those wheels do look good in gloss black powder. I think if you did that, the pipes would look better chrome.
I think that would look good if they were fat spokes. I think you mentioned in another thread that you could get fat spokes for the stock wheels. Do you have an info on where to get them?
