Internal wiring ape hangers
Does anyone remember the thread posted about dis-assembling hand control wiring plugs for internal wire routing. Had pics and step by step instructions. I can't find it in a search. I'm re-building after the winter mods and adding a Roland Sands bar. I don't know how to pull the wires from the plugs. HELP!!!!
I'm just finishing up running internal wires. If you have a newer bike, '07 or later, I think, you'll probably have Molex connectors. I found this post to be helpful, with some alternate steps. In the first picture, he shows pulling the lock plate. For the life of me, I couldn't get it to budge. Instead, from the back, pull the small black (hard) plastic plug out of the connector, followed by fishing out the orange (very soft) silicone seal. From there, you'll see two whitish tabs in the side edges of the plug. Push them with small screwdriver.
Molex plug
I'll take some pics of the black plug and orange seal and post them (if I can figure out hoe to do it on Wife's Mac - I'm a PC guy).
Molex plug
What year and model Dyna? Plugs are different styles for specific years....Lots of people around here can help with either style. I just finished wiring my apes internally about 2 weeks ago (07 street bob). All Molex connectors on mine. The Molex are super easy to take apart, once you see how they work.
Mud has a great post with close-up pics (07 and newer Molex style) and here for the '06 and older Deutsch style connectors.
I know its blasphemy, but i found it easier to just cut the wires and solder them.
(found out after taking a side apart, bending/breaking pins trying to get them out of the bars...etc.)
so in the end i got to take apart the connectors, crimp pins, and solder wires/ then cut the wires, and solder in extensions.. well, i have a plan for the next change anyway..
my suggestion, if you get frustrated, just walk away for a bit, and come back to it. no prizes for quickness, just one for a job well done..
Eric
Eric
Here is a pic of the Deutsch connectors on the 06-07 Dynas. As you carefully pry the rubber seals from the connector, you can tell how to separate the housing components. You can look inside the housing and see the locking mechanism which retains the terminals. Sliding a small pick into the terminal hollow and then pushing the terminal to the side will release it. Slides right out.
