Paint The Air Cleaner Back Plate?
Old 04-17-2006 | 09:20 PM
kaduku's Avatar
kaduku
Default RE: Paint The Air Cleaner Back Plate?
I also noticed this when I first installed my stage 1, and immediately went online to see other bikes, if I could see the silver backplate. It really does stand out on the street bob engine. I would also like to paint this and would have chosen black if I knew that was an option. Does the Arlen Ness Sucker one have it in black or is it just not as visible as the SE one.
Old 04-18-2006 | 02:05 AM
FREEFALL's Avatar
FREEFALL
Here are two pics that show the backing plate. I can deal with it for now. May go to the chrome one down the road.
S/F
TOP
Old 04-18-2006 | 02:11 AM
but Ill try 2 try's Avatar
but Ill try 2 try
now those are instructional, detailed photos
Old 04-18-2006 | 03:19 AM
bobcowan's Avatar
bobcowan
I like that. I like it a lot. I don't think I would chrome it. Where did you get the cover plate?
You can get a rain cover from K&N, it's called a "Drycharger" and works really well.
Old 04-18-2006 | 05:06 AM
CraigC's Avatar
CraigC
Yup, definitely painting mine black! Thanks for the detailed photos.
Old 04-18-2006 | 07:35 AM
Halfbuck's Avatar
Halfbuck
The die-cast doesn't look bad on your's, but the engine area on my Low Rider is all black or chrome, so it stands out a lot more. I can almost hear the spray can rattle now! Thanks for the pics.
Old 04-18-2006 | 04:22 PM
DyNaBoB's Avatar
DyNaBoB
mine came chrom and with the k and n filter for the same price as the blue filter and the dull back plate
[IMG]local://upfiles/8434/13116965EF074B618FAB8CB7DDB926A0.jpg[/IMG]
Old 04-19-2006 | 01:31 AM
FREEFALL's Avatar
FREEFALL
ORIGINAL: bobcowan
Thanks for the compliment.
The cover plate is the Skull H-D a/c insert. Fits perfectly over the S/E filter. (I did have to use a spacer as the stock bolt is a little long)
Semper Fi,
TOP
Old 04-19-2006 | 09:01 PM
Halfbuck's Avatar
Halfbuck
Hey PaulJr,
Did you paint the entire back plate? Even the intake part that the air filter fits over?
Old 04-19-2006 | 10:11 PM
Pauljr's Avatar
Pauljr
I painted the whole cover, cleaned it very well then sprayed it using High Temp. BBQ Paint 2 coats.
[IMG]local://upfiles/7456/56B8C75A836749FB902DB61E2F4FAA51.jpg[/IMG]
Quick Reply: Paint The Air Cleaner Back Plate?
