Throttle friction adjusting screw
I adjusted mine with the bike off. Open the throttle, tighten the screw enough to hold the grip open, then back the screw out until the throttle snaps back closed. Then I backed it out about another 1/8th turn to be sure. Check the throttle return with the bars straight, full left, and full right. The throttle should snap closed immediately when you let go of the grip. I like this setting because it takes some of the slop out of the grip when riding. Also, with it set this way you can use it as a throttle lock cruise control, but you have to make sure that you can manually close the throttle by rolling the grip forward even when the star screw is tightened down enough to hold the throttle open.
Fatt Tony (02-14-2021)
Release your grip completly and you will be cruising at a steady speed.
Then rotate the throttle closed just a little, your bike will slow down, roll on the throttle again, release your grip and you will be crurising again. This will asure you that you still have complete control of your speed.
When you approch your exit ramp use your middle finger (it's the longest one you have) to pull (rotate) the star twords you untile the throttle closes on it's own. This will dis-engage the 'cruise control'.
I use it all the time. It is just like anything else, if you are aware of it and your surroundings it won't be a problem. Just apply enough tension (as stated earlier in this post) to hold it not lock it. It's best used on the open road and real handy for giving the hand a rest on long hauls.
