Replacing rear pulley bolts
Old 01-12-2009 | 06:47 PM
DJM's Avatar
DJM
Stage III
Default Replacing rear pulley bolts
I plan on replacing the rear pulley bolts on my 2008 FXDL with the Harley replacement chrome bolts part (no. 94773-07.) Any tips out there from someone who has done this? Thanks
Old 01-12-2009 | 07:04 PM
2007fxdc's Avatar
2007fxdc
I put the chrome bolts on mine when I added a chrome pulley cover. No big deal, just follow the instructions and torque to the proper spec.
Old 01-12-2009 | 07:12 PM
FUQUA's Avatar
FUQUA
No big deal, just follow the instructions and torque to the proper spec.[/quote]
+1 Not a big deal, I think the torque spec is 60 to 65. I just added a chrome DNA pulley
Old 01-12-2009 | 07:53 PM
Gwjvw's Avatar
Gwjvw
Mine will be on this weekend!!!!!! YAAAAAAAA
Old 01-12-2009 | 11:33 PM
SC-Longhair's Avatar
SC-Longhair
You might want to think about some red lok-tite. Ever seen what happens when the pulley bolts come loose? Not good.
Old 01-13-2009 | 01:55 AM
Doughboy's Avatar
Doughboy
Default ive seen it before
300 miles trip.i was showing someone my rear sprocket after we got there(little sturgis ky).then relized two were missing ,two were bent.one was still holding my sprocket on.did some gouging to my frame.very lucky.RED LOCTITE everything.
Old 01-13-2009 | 05:58 AM
formike56's Avatar
formike56
+2 on the red locktite. It will be a bad if you don't use it. Their is a few post on the forum about what happens when the bolts decide to back out. You are supposed to check them every service.
Old 01-13-2009 | 06:12 AM
dyna rider's Avatar
dyna rider
Default Pulley Bolts
When I replaced my pulley bolts I used blue Loctite on the bolts and have had no problems. Red Loctite has to have heat applied to release the threads. If your rear hub gets hot it won't make any difference if you use red or not. Rear pulley bolts should be part of your preflight checklist.
Old 01-13-2009 | 03:55 PM
jdhodel's Avatar
jdhodel
I cheated and had the dealer do mine when they did my rear tire. Chome the pulley while your at it.
Old 01-13-2009 | 05:54 PM
SuperFastGlide's Avatar
SuperFastGlide
mine had blue loctite from the factory
Quick Reply: Replacing rear pulley bolts
