Where to buy the BEST QUALITY heat wrap?
Pepsi, try a car speed shop. They will probably have the wrap atol cheaper than a bike shop or some online stores. DEI sells 15 ft and 50ft rolls. If you go to DEI's site the setup with 2 15ft rolls, 4 clamps and the can of silicon paint spray (which you should use to protect) sells for like 90 bucks. I went to my local speed shop for cars and got the exact same set up for $46.00. I have no idea how much wrap you would need but at the shop it was only $12 more to get the 50ft roll versus the 2 15ft rolls. Hope this helps, good luck!
I like the Thermo-Tec wrap I bought. 50' was not enough so I changed how I was wrapping a bit, get the 100' roll. There's also a high heat paint for the wrap...it seals it and makes it more water resistant. You can find it on Summit Racing's site. I recommend soaking the stuff before wrapping the pipes too, but some may say it's not a requirement.
Oh yeah...wear gloves and long sleeves.
get 100' Of DEI (great stuff) and a can of the dei black paint. The paint is awesome.
I tried out SE 1st and SE sucks vs DEI. Can be found at advance auto parts. Thermo-Tec may be goos as well. 1 thing about DEI, it never stopped smelling like burnt wrap when it got hot.
Never hmm?
Oh well, a bit of flavor added!
Thanks for the replies guys
