Where to buy the BEST QUALITY heat wrap?
Old 01-09-2009, 06:31 PM
rounder's Avatar
rounder
rounder is offline
Originally Posted by rockon
My Thermo-Tec wrap has already stopped stinkin' and I haven't even put 100 miles on the bike since installing the pipes.
cool if that is the case, however, summer temperatures will tell.
Old 01-09-2009, 06:38 PM
dpriest's Avatar
dpriest
dpriest is offline
i love the smell of burnt pipe wrap in the morning. it smell like.......victory!!
Old 01-09-2009, 07:37 PM
WDR's Avatar
WDR
WDR is offline
I haven't tried Thermo-Tec, but I noticed no real difference between DEI and the Summit brand wrap I bought. As others have said, buy wrap not specifically advertised for a motorcycle. For what ever reason they jack the price up when they say its for motorcycle pipes. I safety wire both ends of the wrap instead of using clamps as I think it looks cleaner.
Old 01-09-2009, 08:18 PM
Pepsimayn's Avatar
Pepsimayn
Pepsimayn is offline
I've heard this will cut into the wrap over time? Any problems with this?
Thanks again
Old 01-09-2009, 08:47 PM
WDR's Avatar
WDR
WDR is offline
I have never had an issue with it cutting the wrap. I use a double wrap of safety wire and make sure to use stainless safety wire and not some cheaper alternative. The pics below are of the start of my last wrap job and the tools I used. The pipes are black Bassani Pro Streets I got off Ebay for $150. I double wrapped the portion closest to the motor. You can see the safety wire at the end of the pipe. I wasn't worried about how it really looked, since it would be covered by the second layer of wrap.
Old 01-09-2009, 11:28 PM
rockon's Avatar
rockon
rockon is offline
I wrapped both pipes starting at the header and moving towards the muffler. As mudpuddle will also testify, if you wrap tightly, there is no need for a clamp at the starting end. You can start at the muffler end or the header end, but if you wrap it correctly, the tension of the wrap will hold the start point in place...then just clamp the finished end. Hope this makes sense.
Old 01-09-2009, 11:46 PM
mopardave's Avatar
mopardave
mopardave is offline
I bought the DEI and it holds up good. i used the high temp spray silicone on them too.
http://cgi.ebay.com/ebaymotors/DEi-T...Q5fAccessories
Old 01-10-2009, 12:07 AM
Pepsimayn's Avatar
Pepsimayn
haha Dave your avatar is amazing.
Thanks for the help guys, guess I will be going with the DEI stuff!
Old 01-10-2009, 12:16 AM
mopardave's Avatar
mopardave
Thanks! Good luck with your new exhaust!
P.S. Thunderheaders sound killer!
Old 01-11-2009, 12:44 AM
Pepsimayn's Avatar
Pepsimayn
Gents,
One more thing, I was wondering how much you paid for the DEI at advanced auto, or the like? Would it be better to wait and buy it local or is there a place to get it cheaper online?
Thanks a bunch!
Quick Reply: Where to buy the BEST QUALITY heat wrap?
