Ebay Side mount Plate
25mm is 1 inch axle actually it's .98 of an inch, but close enough. All you would have to do is drill out the mounting hole a little. It's not visibal under the axle nut anyways, so you wouldn't need to re-powder it. Did you try mounting it before you sold it??
+2 on what Shockwave said.
I bought one very similar to that one off a member here about a year ago and mounted it the same way you did.
Lasted about 6 months and broke off at the eyelet where it bolted up to the beltguard.
Granted, this was after I hit a pothole.
Only cost me 15 bucks, but it cost another 28 to replace the plate I lost and another 20 to have a bro' make a bigger and better one for me.
Just food for thought.....
Yeah, I tried mounting it and it wouldn't fit. I could've drilled it out, I considered that for a while, but decided I'd rather buy a nicer one that fit rather than having to buy the tools to bore it out.
I was going to get one of those kuryakyn mount covers, but don't really like them. Found only like two others and don't like those either. So today I ordered some spike license plate bolts so we'll see what they look like when they get here. I'll put them on as chrome and if I don't like it I will paint them black and try that. Just going to play with it since it's winter and snow everywhere I figured I have time to see what I like. Thought about skull bolts, but I don't want to over due the skulls because my paint job has enough and three of them under 3 painted skulls is to much. I might do the top hole with a bar and shield or an Iron cross and the two bottom ones as spikes. Like I said I have time to play with and I put up some pics hopefully next weekend.
