Suspension/Brakes upgrade!
I've got a case of cabin fever since it's freezing and snowy here, but that means it's a perfect time to work on the bike. I sold my sportbike last week so I have some extra money to put into the Harley. I've been sorely disappointed in the suspension and brakes so far, probably because of what I'm coming off of (Yamaha FZ1). Plus I've got a trip to the Dragon coming in May, so I must get the ground clearance raised a bit. I don't care for the slammed look, and I already scrape pegs ofter as it is.
So here's what I've got coming:
FXDX-T rear shocks, got them on Ebay for $160. I've ridden a T-Sport and although I didn't really flog it, I did like the higher seat and ground clearance. For that price, I don't think I'll get more shock for the money anywhere else. Why did HD quit using the good suspension components they used to use anyway?!
Progressive fork springs and 10w fork oil. I've found I can bottom out the stock forks without really trying (I weigh 215). Hopefully this will stop.
Superbrace. Had one on my V-Strom, amazing upgrade for the price.
Two sets of HBC HH Sintered brake pads. Supposed to be a good upgrade, I'll combine those with stainless lines at some point.
I got the Dyna factory service manual for Christmas, and I ordered the fork cap socket from Ebay this morning. I've already got a jack and an assortment of tools. I think I've got everything I need.
Any tips? Thoughts on this upgrade? Comments? I'm looking forward to the UPS guy showing up next week
Sounds trick MZ. Should give ya some good handling.
I know I'm disappointed in the brake performance of my FXDC... specifically the rear brake. Some items in my future: 4 piston rear caliper, better pads front and back, superbrace, true-trak and braided lines. May take me awhile to put that all together, but I know the end result will be sweet.
The FXDX shocks are almost an inch longer than stock. Make sure you are not messing up your trail. You might have to increase the length of the front suspension. The bike is going to steer a lot quicker.
buckeye,
You're headed in the right direction. The only change I would make is to stay away from the progressive kit for the front end. Go with Works or Race tech in the front end. As for needing a longer kickstand and such...not true. Here's a pic of a streetbob a friend did with FXDX shocks in the rear. Ofcourse there's a 21 on the front which levels it a bit, but you should be alright.
Stock shocks are 12.5 these are 13.5, how will it end up 1.75" taller? I don't think it will be a problem. The FXDCI sits pretty low in the back stock, so I don't see 1 inch being an issue with stability.
Here's a picture of a board member's bike with 13.5" Ohlins on the rear, to some it may look dirt-bikeish, to me it looks like a dyna that's ready for the twisties, which is what I want mine to be. Function over form, I happen to think it looks good sitting higher, more sport/tour/cruise, if that makes sense
As far as the front end, the Progressive springs were only $67, so I figured they're worth a try. I'll take a look at that other stuff though while I'm waiting for it to ship, I'm sure I can resell the Progressives if there's a better route.
Checked that pic against the two dirt bikes in my shop..nope; don't get it...cannot see any resemblence. On the other hand; a lot of lowered bikes look like an invisible 500lb rider is sitting on them.....
Done pretty well all I think I could to my FXDXT; rear brake still sucks.....but it sure handles good, stops well and is relatively quick for a Harley.
I've used the race tech emulators and springs in my last bike, a 100hp Sporty...really did good in what's essentially the same front end (39mm tubes). Off course the FXDXT is fully adjustable, so it's "stock" on my bike.
Good rubber will make a big difference, too...but be prepared for less mileage; coming from a sport bike, you're used to that already.
Less unsprung weight, better brakes (and maybe engine mount) adjustable suspension and stickier tires should make you happy...
'01 FXDXT
103 by HQ
bunch of aluminum and composite
620lbs wet weight
On the road 2-up:
'01 FXDXT
103 by HQ
620lbs wet weight
On the road 2-up:
'01 FXDXT
103 by HQ
620lbs wet weight
On the road 2-up:
'01 FXDXT
103 by HQ
620lbs wet weight
On the road 2-up:
Sweet pic, sweet bike!
Hey, how hard is the install of those race tech emulators? I was pricing those out, the emulators and for springs, not TOO bad. I'd like to avoid complete front end disassembly though. I don't quite know what those emulators do, where they sit, what they look like, etc.
