Grip install - Doesn't fit properly or what?
Old 12-26-2008, 01:15 AM
AdrianVall's Avatar
AdrianVall
AdrianVall is offline
Default Grip install - Doesn't fit properly or what?
Hey guys,
I meant to post this last week, but I've been putting it off.
I bought these nostalgic harley grips from Harley. As I was installing them on the throttle side, I can't tighten down the switch housing all the way or else the throttle locks up. Like the inside of the housing is clamping down on the cables, making it unable to move. And I can't adjust my cables all the way cause that locks it up as well. I had to put a very thin, tiny plastic spacer in the housing so that I could tighten the bolts down, but it was just a temporary fix. Any suggestions? Its really beggining to annoy me... I have quite a bit of play in my throttle since its not all the way adjusted. The throttle doesn't feel tight at all.. kinda hard to explain but its just loose and has play in it. Anyway, thanks guys!
Cheers,
Adrian
Old 12-26-2008, 03:53 AM
jmpancoast's Avatar
jmpancoast
jmpancoast is offline
First suggestion, and not meant to sound insulting, are you sure the throttle lock isn't screwed in? Check the friction pad for the throttle lock and make sure it is seated properly.
If these don't remedy the problem, take a break, pull the throttle side off and redo it. Maybe something didn't go right and you missed it the first time around.
Old 12-26-2008, 07:38 AM
sniper77's Avatar
sniper77
sniper77 is offline
Throttle lock is located on the lower housing between the throttle and idle cables.
Old 12-26-2008, 07:44 AM
rounder's Avatar
rounder
rounder is offline
also be sure the grip is about 1/8" away from the end of the bars.
Old 12-26-2008, 08:23 AM
SC-Longhair's Avatar
SC-Longhair
SC-Longhair is offline
Like I learned from doing HVAC for 4 yrs...make it work.
Old 12-26-2008, 08:35 AM
don03's Avatar
don03
don03 is offline
What Rounder said. I put new grips on and had that problem because I pushed them all them on the bar, gotta back then up a hair and everything fits nice.
Old 12-26-2008, 08:44 AM
jfm5's Avatar
jfm5
jfm5 is offline
glad you posted this because i was having the same problem just backed the grip a knats bollock and its now fine
Old 12-26-2008, 08:53 AM
Sumpnut's Avatar
Sumpnut
Sumpnut is offline
Oh so thats what it is.. thought it was an air speed fan lmao..no seriously I did'nt know..but I do now : P
Old 12-26-2008, 09:29 AM
rounder's Avatar
rounder
rounder is offline
another thought too... the throttle lock has a little black piece that is smooth and rounded and just fits on the end of the screw mechanism... is it properly in place?...can fall out real easy.
Old 12-26-2008, 09:32 AM
rjmac53's Avatar
rjmac53
rjmac53 is offline
Let us know what happened...
Quick Reply: Grip install - Doesn't fit properly or what?
