Does superbrace offer any discounts for HDF members?
I like the idea that the Superbrace for polished aluminum forks won't quite fit on chromed ones. That shows me just how close their manufacturing tolerances are. Any fork brace that will fit both non-chromed and chromed forks is really made to fit neither properly.
![Big Grin](https://www.hdforums.com/forum/images/smilies/biggrin.gif)
I'm a happy camper...
BTW, a big thanks to Gearhead383 for the discount info...you da' man.
I was searching and found this...
"Also, we're offering 25% off all Harley SuperBrace Group Buythrough www.superbrace.com. Simply place your order and enter the coupon code: supersaleand instantaneosly see the discount applied. We have some in stock, so now is a perfect time to take of the advantages of the savings before they're backordered!"
I entered the code at their site and it worked. Saved a little over $35.00. Hope this helps!![Wink](https://www.hdforums.com/forum/images/smilies/wink.gif)
If you ride such that you actually need the True-Track (or similar product) a fork brace isn't going to help you all that much. If you are a more typical rider, who rides at no more than 7/10ths even when pushing it, then the Superbrace will give you better straight line tracking and tighter turn in on the corners.
Thanks Gary!
Seems like the Superbrace will be my choice.
Appreciate the advice.
Two entirely different animals designed to correct two different "problems."
