Just got a superglide custom tonite.Don't know if it has a battery connection for the battery tender,it's supposed to.It's in the garage,not much light,I can't find the damn thing.Where would it be?I'm lookin all around the battery. Any idea?
My lowrider came with one but the dealer told me they installed it as a courtesy to their customers. It is located alongside the battery box just above the swingarm.
That's all fine and well,but it's going to be 3 degrees here tonite! Here she is all hooked up! How cold does it get by you guys?
when you get a chance swing by your stealer to get the permanent connector. It is only 10 bucks. then you can just plug in and out anytime without having to mess with mounting those alligator clips.
Also look at your battery. Is there more than the pos. and neg . cable attached to it? If you have additional wires attached to each terminal, then you probably do have the plug installed and just missed where they routed it.
all the mechanics I have talked to (stealer and independent) feel that tendering the battery every night possible leads to longer battery life.
I didn't have one on my '06 Superglide but added it myself - its a great addition, especially in the winter time or when you are away from your bike for a while.
I looked on my Fat Bob just to see and I did find a wide/flat connector with 4 wires going into it that is capped off. I don't have a manual for reference but with 4 wires I would have to guess it might be the OBD connector.....that isn't it is it?
I found it.It has one.It was on the left side,behind those 2 big spark plug looking wires.It was tucked in there.I fished it out a little when the seat was off.Well at least I know i can remove the battery cover and seat without destroying anything.
Reason: picture edit
Congratulations Chopperz
Youre now a certified HDF Harley mechanic
