Installing exhaust on 06 Dyna
Old 04-11-2006, 07:38 PM
stbobber's Avatar
stbobber
stbobber is offline
Default Installing exhaust on 06 Dyna
IS it a hard job for a backyard auto mechanic? I'm sure some of you guys have installed your own exhaust, just trying to save a little cash.
Old 04-11-2006, 07:44 PM
hd_sob's Avatar
hd_sob
hd_sob is offline
Default RE: Installing exhaust on 06 Dyna
After having seen how much difficulty the dealer had putting the V&H on my Sporty, I personally don't think I would attempt it. Especially without a rack or very sturdy stand.
Of course, I imagine no two installations are identical and some go on much easier than others. The stand is definitely something to consider though...
Old 04-11-2006, 07:54 PM
jaystone's Avatar
jaystone
jaystone is offline
I installed a set of V&H on my wifes 05 Sportster and my 05 Wide Glide. I wouldn't say it was a piece of cake, but I would think anyone that is even slightly mechanical can do it. Save yourself the money and do it yourself. The tools you need are just the basics.
Old 04-11-2006, 08:12 PM
kaduku's Avatar
kaduku
kaduku is offline
I saved alot of money installing my slip-ons and stage 1, so I would do it myself. In fact, I plan to do my own 1000 service on my own bike. Take that you stealers!
Old 04-11-2006, 08:36 PM
phreak's Avatar
phreak
phreak is offline
It's do-able. Take your time, be patient. If you don't have the right tool, go buy it. You'll use it again later.
Old 04-11-2006, 08:42 PM
sturgis kidd's Avatar
sturgis kidd
sturgis kidd is offline
if its a bike with fuel injection, you might have to step up to a stage 1 and different air cleaner.. might want to check in on that...
Old 04-11-2006, 09:45 PM
jackyl's Avatar
jackyl
jackyl is offline
not that bad to do,takes some time about 2-4 hrs ,depending how good your with a wrench.i would do it yourself,save some cash.its not that bad.might need a little hand holding the end of the pipes while you wrench the front down to the heads.but all in all,i give it a 4 on a recter scale of 1-10.plus u learn your bike,and it will make you feel better inside when you look at your exhaust,knowing you did it yourself.
Old 04-11-2006, 09:46 PM
dajam_fxdli's Avatar
dajam_fxdli
dajam_fxdli is offline
I am going to put on a set of Rineharts 2 into 1's in a few weeks. I can't imagine it would be that hard? Rather do it myself and save a few bucks... I will let you know how hard it is....
Old 04-11-2006, 10:56 PM
but Ill try 2 try's Avatar
but Ill try 2 try
but Ill try 2 try is offline
I'm thinking of installing some air in my rear tire by myself, but only when it's necessary. I've read where most any air will fit an 06 dyna as long as you get it in the tire. Do the o2 sensors cause a problem for this, as ambient air is only about 15 or less percent oxygen. Just wondering. Will the same air fit the front tire? I know a guy with a new 1200L and he puts the same air in his front tire as I would put in mine, but he has a 21 inch front and my Bob has a 19. Didn't know if he had to use larger air. So much to keep straight!!!
Old 04-11-2006, 11:02 PM
jackyl's Avatar
jackyl
jackyl is offline
i perfer warm air in my front tire and cold air in my rear tire.lol
Quick Reply: Installing exhaust on 06 Dyna
