high intensity bulbs for a fatbob
Old 12-17-2008, 04:02 PM
arnold's Avatar
arnold
arnold is offline
Default high intensity bulbs for a fatbob
I went to HD today to get some zion headlight bulbs, they say they don't make em. Anybody know where you can get em?
Thanks
Old 12-17-2008, 04:43 PM
sanman357's Avatar
sanman357
sanman357 is offline
https://www.hdforums.com/forum/dyna-...b-upgrade.html 9008 aka h13 bulbs should work. From looking around that is the bulb that is on the Fatbob.
Last edited by sanman357; 12-17-2008 at 05:02 PM. Reason: Did search and found link
Old 12-17-2008, 05:34 PM
JRK5892's Avatar
JRK5892
JRK5892 is offline
went to harley for a light bulb???? go to the auto store and get a silverstar bulb... will not say harley on it but i promise they still work
Old 12-17-2008, 05:42 PM
arnold's Avatar
arnold
arnold is offline
HD makes zion (or at least sells them) for the other dynas, I'm actually looking for something like that. or at least a brighter light, I ride at night a lot it would help. I would like a part # for a bulb that has been trid successfully by someone. The link was nice but not definitive.
thanks
Old 12-17-2008, 05:45 PM
JRK5892's Avatar
JRK5892
JRK5892 is offline
dude the silver star is going to be the brightest thing next to HID...
Old 12-17-2008, 06:13 PM
arnold's Avatar
arnold
arnold is offline
Ok Ill give that a try, thanks
Old 12-17-2008, 06:40 PM
jwlehman's Avatar
jwlehman
jwlehman is offline
Is it difficult to do the cross-reference, and get the correct Silver Star bulb to fit a Fat Bob? May sound like a stupid question, but I've never looked at the cross-reference charts to buy a Silver Star bulb for a Dyna. I did find a rebate for Sylvania bulbs at:
http://www.sylvania.com/content/disp...x?id=003697635
Old 12-17-2008, 06:54 PM
Mr. Lucky's Avatar
Mr. Lucky
Mr. Lucky is offline
You're thinking of Xenon (pronounced "zee-non"), and there's a lot more to it than a simple bulb swap. Go with the suggestion of SilverStars - they have a shorter lifespan than stock, but they are brighter.
Old 12-18-2008, 07:28 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,866 Likes on 2,429 Posts
What you need to know first, is the type of bulb fitted. This is typically called H4, or something similar. My old Glide used H4, my Firebolt has two H3.
Once you know the fitting, simply Google car bulb suppliers and chose your poison! I have just received my Osram 'Night Breaker' bulbs that I will be fitting to my Buell. I already have a factory HID unit on my Glide, but don't recommend it.
Look for the bulbs that give the highest temperature, typically 2,000 degrees or higher. HID gives around 6,000 as I recall, but 4,000 deg is possible from the better replacements.
Be wary of going to higher wattage, as the wiring may not be up to providing it without over-heating.
Old 12-18-2008, 09:07 AM
benwiggin2's Avatar
benwiggin2
benwiggin2 is offline
Stock, it's an H13.
Quick Reply: high intensity bulbs for a fatbob
