How to install brake lights in rear turn sigs?
Hey guys,
I want to put on the brake light/running lights in the turn signals, just like the nightster has. Is this able to be done without any major modifications? I know a couple of you have done it, so if anyone could help me out I'd greatly appreciate it. Thanks fella's!
Cheers,
Adrian
Cheers,
Adrian
takes about 5 secs to install, all you do is take your seat off find the main wiring harness. disconnect the plug that the instructions tells you to, then plug the device in and your good to go. all it does is piggybacks your wiring harness. very simple, you can do it in the parking lot of the dealer. i think it is a must have on a bike.
No, just buy the run, brake ,turn module from harley. It just plugs into you wiring harness under the seat and thats it. No need to change any thing else. It'll make a big differance since you have your brake and running light on the side of your bike. I was able to get rid of light when I chopped the fender.
