Question about removing mufflers
I'm probably going to wind up putting different mufflers on my Super Glide, so I have a question about getting the old muffs off. On my Sportster, because the crossover nipple is part of the muffler neck, you have to loosen the header bolts at the head so that you can lift the muffler up off the crossover port and then wiggle it off the header pipe.
I looked closely at the Dyna exhaust system today when I was at the dealer and the crossover pipe is welded to the header pipes. This should mean that taking the mufflers off is a simple process of loosening the clamps and unbolting the mufflers and then wiggling them off. Is that right? You don't have to loosen the header pipes at the heads like on the Sporty, correct?
No thanks. I don't like a real loud exhaust. I may just keep the stock mufflers if I like the tone and can actually hear the exhaust while cruising down the road. That was my main beef with the stock mufflers on the Sporty: You could not hear ANY exhaust noise when you were riding. I like a little Harley rumble as background music when I'm riding.
