battery problem
Old 12-11-2008, 06:12 PM
eagle1's Avatar
eagle1
eagle1 is offline
Default battery problem
I have a 07 street bob. I let the bike sit for over a month. I tried to start it and no luck..Anyway took my battery into the dealership last saturday. He said I just need a battery tender. Well the voltage is up to 13 since it has been on the tender. I have tried to start it and still dead. I read in the manual that it should be @13.7. It seems that it has topped out at 13. Can someone shed some light on this for me. Eveything else on the bike is fine.
thanks
Darren
Old 12-11-2008, 06:16 PM
t150vej's Avatar
t150vej
t150vej is offline
Received 1,823 Likes on 1,183 Posts
They should go higher on a charger and I don't know what kind you have. A small trickle charger won't "heat" them up much, but provides for maintaining a charge and will (should) over the course of a day or 2 bring a battery all the way up - assuming the battery is good.
Is it a sealed battery? and do you know what the output of the charger is (amps) and how long has it been on charge?
Old 12-11-2008, 09:32 PM
ssls6's Avatar
ssls6
ssls6 is offline
thanks
Darren
The bike should start with a battery at 13V. A battery at 12.7 is fully charged. The 13.7 number is with the motor running let's you know the charging system is working. I would make sure the cables are tight and measure the voltage while pushing the starter button.
Old 12-11-2008, 09:34 PM
rdondes's Avatar
rdondes
rdondes is offline
Make sure your batter terminals are tight.
Old 12-12-2008, 11:32 AM
eagle1's Avatar
eagle1
eagle1 is offline
It is the Harley super smart Battery Tender: When I turned the ignition on today the voltage dropped to under 12v to 11.8. So when i hit the starter nothing. The battery is sealed. I made sure the terminals were tight too. Any more ideas.
thanks for your help
Darren
Old 12-12-2008, 12:26 PM
dyna rider's Avatar
dyna rider
dyna rider is offline
Default Battery Problem
Does the yellow light ever go out on the battery tender and go to flashing green or solid green ? If not you probably need a new battery. I would let it charge for a day or two and if it still doesn't start a new battery is the best bet. Have you checked all the main fuses with a multimeter ?
Old 12-12-2008, 12:29 PM
roberttroll's Avatar
roberttroll
roberttroll is offline
Leave it off the charger for 48 hours then re-test the voltage. If it is below 12 then you got a bad battery.
Old 12-12-2008, 12:41 PM
ssls6's Avatar
ssls6
ssls6 is offline
Darren
Sounds like a bad battery. 11.8V is almost fully discharged. You can put a set of jumpers to the batter from another battery (like a car battery) and try to start it.
Old 12-12-2008, 12:59 PM
eagle1's Avatar
eagle1
eagle1 is offline
Thanks I will take it off the charger and try to jump up and see what happens..I am thinking it is a bad battery..we'll see.. The battery tender light was a blinking yellow to a solid yellow..thats when i tested it to be 13 V.
Old 12-12-2008, 02:40 PM
dyna rider's Avatar
dyna rider
Default Battery
Blinking yellow is not charging. Solid yellow is charging but battery is less than 80% charged.
Quick Reply: battery problem
