Fat Bob scraping sound problem
THIS IS A HUGE +1... alot of scraping has to do more wiht you body possition on the bike while you are turning... you should try to stay high on the bike to keep you weight over the center of the bike durring a power turn... push on the bars as you do this to get a strait line... (from the little sessions i have has on the track with rockets) but it does help you to come out of your turn and on a bike with good sport suspension you will actually feel the bike lift you up out of the turn, this makes it easier for you to lay into the next one... fork braces and stearing dampers REALLY help this!!!!
Amen on the body position for turning, which is why I went with mid-mount controls. The farther I can hang out reduces lean angles to make turns, allowing for more speed, but there does come the point where the pegs touch down anyway...with raising the bike giving that few more degree lean angle. Ain't gonna take it so far as to drag the primary or the pipes, just close. Draggin hard parts would surely be scary, probably disastrous if it lifted the rear tire.
I wasn't gonna say it, but I was thinking it! I took off my passenger boards and mounts because I hit the left side on my '05 a little too solidly a couple of times which was scary (and because I never use them lately). I've also cranked up the shock adjustments a bit since then which has helped.
http://www.youtube.com/watch?v=OmhlP...eature=related
I'll bet this guy goes through a bunch of pegs! hehehe I've never seen such a thing.. He's racing a freakin' Harley!!! You gots to be jokin'!
"A man has got to know his limitations".
I think that was a quote from Magnum Force
