air shock line kit
mine came in a little package... for 30.00 dollars had the air fitting and enough hose to do the job... then an additonal 6 bucks a piece for the push in fittings... granted that was 2 years ago but it can not have changed that much! didnt you air fitting come wiht like 3 ft of hose?
I just talked to the only HONEST dealer in the area City limits... the air fitting is: 34.00 comes with hose, and the fittings needed to make it work... part number: 54536-02A (02 and later)
and the push fittings are: 5.95 Part number: 54320-97
total: 44.95
does not look like i was WAY off...
they took you brother! typical Harley... I included the part numbers above so you can go back and return them and pocket an extra 60 bucks back into your wallet.
total: 44.95
