Wind Buffing
With the windshield on my WG, i get some pretty serious buffeting wearing a FF helmet. The simple solution was to wear something that blocks the open area of the helmet around my chin - easy to do when it's cold.
Oddly enough, I ride with my faceshield open a lot. You would think the open faceshield would create some weird wind issues, but, it doesn't.
I think it has to do with the angle of the H-D windshield and for some, the shape of the helmet they are wearing.
I had bought a cheap full-face made in China at first and the wind whipped that helmet so bad I couldn't wear it for any length of time. I upgraded to a good helmet and the airflow around it was drastically better, smoother than the original. No more "bobblehead".
As to the windshield, the H-D appears to be nearly vertical with little to no curvature. The windshield does not even flow with the rake of the forks.
When I first installed my National Cycle windshield, I had it mounted fairly vertical and took it out for a test ride. By moving forward and back in my riding position I could tell how the wind was channeling around and over it. I kept moving until I found the "sweet" spot. I went home, adjusted the shield so it leaned back at a greater angle than the fork rake and as I said in my earlier post, the wind channels across the top of my head very comfortably.
I'm looking to buy a new shield since the original was broken in the crash. I've been bidding on the H-D detachable on ebay but with the apparent dissatisfaction of many of you with it I think I'll go with either another National or maybe a Memphis that actually has some adjustability and slope/curvature to insure I don't regret my next purchase.
A very annoying sensation from turbulent wind coming off a windshield or fairing. I heard it best described as the feeling that someone is whacking your helmet with a tackhammer. Makes your head bobble around, blurs your vision, etc. If you've got it, you'd know it, it's annoying as hell.
