New Headlight on Fat Bob
Old 01-09-2009, 09:31 PM
mopardave's Avatar
mopardave
mopardave is offline
That headlight is a killer deal. I'm buying one!
  #72
Old 01-09-2009, 09:35 PM
Gary7's Avatar
Gary7
Gary7 is offline
Make sure you get the 5-3/4" one if you've got a stock Dyna headlight.
Also, you'll have to modify the set ring inside the headlight housing because the stock Harley headlight (the H4 clear lens/fluted reflector type) uses one set tab and these lights use the normal three. You have to take the ring out and cut notches at the correct spots to match up with the tabs on the back on the new headlight.
  #73
Old 01-09-2009, 09:52 PM
mopardave's Avatar
mopardave
Cool, good info. I actually have a Nightrain and I'm gonna get a 7" housing to put one of their 7" lense/bulb combos in, so the 5 3/4" will be on the shelf.
Someone mentioned using wire nuts to hook up the light. They are prone to falling off from vibration and for a few bucks you can buy a pack of crimp splices or crimp plug terminals and crimp them with a vice grip. For a few bucks more you can buy the crimping pliers...either way you will be way ahead of those wire nuts.
  #74
Old 01-09-2009, 10:03 PM
Lorance66's Avatar
Lorance66
Lorance66 is offline
If I hadn't wanted mine to be easily interchangeable I would have soldered the wires back together with heat-shrink tubing over it. That would be the best permanent installation I would think.
  #75
Old 01-09-2009, 10:16 PM
mopardave's Avatar
mopardave
Yup, that is the best way to go.
  #76
Old 01-09-2009, 10:35 PM
dcmassena's Avatar
dcmassena
dcmassena is offline
That's one of the cooler mods I've seen on a Fat Bob. Awesome.
  #77
Old 01-09-2009, 10:40 PM
Forgetful1's Avatar
Forgetful1
Forgetful1 is offline
very nice
i was thinking of that same thing
now i know what it would be like .nice very nice
  #78
Old 01-09-2009, 11:38 PM
Gary7's Avatar
Gary7
Gary7 is offline
I just remembered that the forks are wider on the Fat Bob. Do you think I'll have any clearance problems putting a 7" headlight on my Super Glide?
  #79
Old 01-09-2009, 11:49 PM
mopardave's Avatar
mopardave
I am trying not to be a wise *** but, did you measure the space where it needs to go? The 7" headlight housing is a little bit wider than eight inches, I think.
  #80
Old 01-10-2009, 12:11 AM
Gary7's Avatar
Gary7
Gary7 is offline
No. But I don't think it's going to be a problem. Based on this photo of his bike, you can see how far forward the headlight sits from the fork tubes:
Quick Reply: New Headlight on Fat Bob
