HELP--Making Dyna Hard Bags Removable
Hello to all,
I have a 2005 Superglide with color matched hard saddlebags. My only issue is that they make it very difficult to clean the back end of the bike. I have tackled making them easily removable, but I need some input.
THe bags are only held to the bike using the 2 fender strut bolts. The bolts are grade 8 3 1/2 inch long bolts that come in from the back of the fender, through the strut and sisybar sideplates, through the bag where there is an acorn nut holding it all tight.
What I have attempted to do is get a bolt that is 1/2 an inch longer with threads the whole length of the bolt. I put a chrom 3/8 nut between the fender strut and the saddlebag locking the fender, strut and sideplate to the bike securely. Then I can slide the saddle bag over the remaining lenghth of the bolt and add the acorn nut. This allows the bags to be removed in 2 seconds by just removing the acorn nuts.
My only concern is the original bolts which came with the saddlebag kit were grade 8. I cannot find grade 8 bolts without a shoulder (treads all the way down) The head on the bolt is also approcimately 1/8 of an inch thicker than the original, moving it 1/8 of an inch closer to the tire, but it does not stick out any further than the signal wiring clips inside the fender.
The saddle bag seems to be just as secure as before.
My questions are.....
1-Can I use a standard steel bolt instead of grade 8?
2- Is the head still safely away from the tire? (safety first)
3- Will this all stay together.
Heres a few pics.....
Any input is greatly appreciated.
Aron
Aron
I have thought about this too. My idea was to get a bolt log enough to have treads all the way throu the bag, spacer, a locking nut and treaded into the finder brace. But be long enough to have 1/2 treads in bag and cut the head off bolt and put accorn nuts in bag. I know thats kind of long winded I hope you understand what I mean.
Hard Bag Mods
Not only is this a good idea----quaifies for under $50.00 but it is applicable to any bags with the factory holes 10 1/2" apart REGARDLESS of what HD says they fit, I am planning to put a stiffining plate on the inside of a set of bags and then follow the instructions on this installation
