Smoked Tail Lights
I had that black one and gave it to my brother because I ordered a red one to go with my new tins.
That looks really nice.
Did you use regular spray paint or plastic paint?
I believe we have some plastic paint in flat black that would probably work.
I think I am going to do something about the plate light since I went sidemount with it.
I used regular flat black spray paint.
Okay, confusing thread to start because the poster put tail light in the subject line but went on to ask about signal lights. So, sorry for me response on the tail light.
I started out with the HD smoked cover kit, which comes with amber replacement bulbs by the way. I think the kit was 30 bucks or might have even been 40. Not worth it quality wise. I was careful and still cracked the clips on a couple of my old covers taking them off and then cracked one of the new ones putting them on. Ended up losing one, buying a replacement, then losing another. So, I bought some smoked covers from Kuryakyn that have chromed housings. Also came with irridium bulbs so they don't show through the covers so much when they are not on. I'm happy with those. A little more expensive but sometimes you get what you pay for.
A little dimmer running light but the signals are still very bright.
I originally checked it out by pulling off the tinted lenses then used a piece of a black trash bag to cover the reflector and put the tinted lens back on (you might want to try that). I used flat black paint, if your concerned with brightness, use gloss black. That should reflect more light than flat black.
Found this on You Tube:
zzr600 painted front signal lens
http://www.youtube.com/watch?v=FNT62bAPks8
Seat Hold down Screw
[quote=WS6 Formula;4136442]Here's the Kuryakyn Deluxe Smoked Tail Light without the integrated turn signals P/N 4974 http://*******.com/5564l2. It has a light tint and you can see the wiring behind the LED light face plate, so I painted the inside of the lense to hide the wiring and painted around the LED lights to darken the overall look of the tail light.
Also have the Harley Davidson tinted turn signal covers P/N 69304-02 http://*******.com/6n4hj6 with the reflectors painted black.
Hello, where did you get your "Colored" seat hold down screw ?
Thanks, Wonka
Thanks, Wonka
Brighter Bulb ?
Thanks , Wonka
I have the smoked h-d lenses with l.e.d. bulbs and if you go this route see my thread.
https://www.hdforums.com/forum/dyna-...te-w-pics.html
i have since switched to the visor lenses and have the old smoked lenses
if your interested pm me
