Shock adjustment
Old 11-18-2008 | 06:11 PM
Shark46's Avatar
Shark46
Default Shock adjustment
I have a 2009 FXD and have never adjusted the shocks whether riding 2 up or alone...should I buy the tool and be adjusting them?
Old 11-18-2008 | 06:21 PM
Topspin's Avatar
Topspin
I left mine in the middle. I'm 5'10" and 175. It is fine there.
Old 11-18-2008 | 06:36 PM
bberck's Avatar
bberck
I would adjust them and see where you like them the best.
As for the tool you dont really need it.
Old 11-18-2008 | 06:37 PM
rdondes's Avatar
rdondes
An inexpensive Sears, strap wrench is all you need to rotate the shocks. Use the strap wrench on the bottom of the shocks around the holes on the bottom cover. Turn counter-clockwise to reduce preload, turn clockwise to increase preload. Should be five settings total (least preload = 1, most preload = 5).
Old 11-18-2008 | 07:27 PM
coop creek's Avatar
coop creek
I use a strap wrench too, it works better than the harley tool and it wont scratch the chrome. I usually make the shocks one click firmer when riding 2 up. It only takes a minute to turn them.
Old 11-18-2008 | 08:05 PM
l.ray's Avatar
l.ray
I agree with you, main thing is , dont use a channel lock.
Old 11-18-2008 | 10:32 PM
Splatter's Avatar
Splatter
Nothing really wrong with having the right tool, though.
Old 11-19-2008 | 01:01 AM
ZChan's Avatar
ZChan
If you plan on changing it alot, get the tool or a strap wrench. I have the dealer change mine to try different settings. Then I leave it there.
Old 11-19-2008 | 06:08 AM
rounder's Avatar
rounder
the tool is $10. just get the tool. turn the adjustment clockwise to firm up. You will notice an improvement in 2up riding for sure.
Old 11-19-2008 | 07:03 AM
0lowrider1's Avatar
0lowrider1
once you get in the habit of adjusting your shocks you will notice a big difference in ride,especially two up........
Quick Reply: Shock adjustment
