Shock adjustment
Old 11-19-2008 | 10:16 AM
tstyles's Avatar
tstyles
I would just get the spanner wrench from Harley. That way you can change the settings depending on if you're solo or riding 2-up.
Here's the part number: 94448-82A retail: $10.95
Old 11-19-2008 | 10:52 AM
Bill-FXDF's Avatar
Bill-FXDF
Adjusting the rear shock pre-load is for additional weight. It tends to make the ride a bit smoother with a rider on the back and helps to keep your shocks from bottoming out on bumps. The tool that Harley sells works great, if you use anything else to take the chance of scratching up the shocks, which may not be worth saving a couple of bucks on a tool.
Old 11-19-2008 | 12:28 PM
captn kirk's Avatar
captn kirk
6th Gear
Default shock
I just picked up a 07 FDX What would be the setting for the driver at 225 and what would the shock be set at with a 150 passinger
Old 11-19-2008 | 12:33 PM
FUQUA's Avatar
FUQUA
Just convert to a hardtail like mine and get a back brace.....lol
Old 11-19-2008 | 01:22 PM
Mascman's Avatar
Mascman
God gave you the tools you need...grab them and twist them!
If you can't get a good grip, use one of those rubber sheets for opening jars.
If I needed a tool, I would probably grab the Sear's strap wrench as it can be used for other things and may be worth having.
Old 11-19-2008 | 03:45 PM
Black Bart's Avatar
Black Bart
I would stay away fromt the HD spanner wrench its garbage. Get and adjustable spanner from Sears. It might cost a little more, but it's well worth the additonal cost. And it is easier to use.
Bart
Old 11-19-2008 | 04:27 PM
06SuperG's Avatar
06SuperG
Check with a stealer. They get anadjuster with every Progresive. They'll probably give you a pair.
Don
Old 11-20-2008 | 07:20 AM
tstyles's Avatar
tstyles
I'm around 200 lb and my shocks were originally set at 3. The ride was too rough. I lowered the setting to 2 and it's much more comfortable.
With a passenger, the 3 setting was okay. I would suggest you play around with the settings until you find one you like.
Old 11-20-2008 | 10:15 AM
MZBuckeye's Avatar
MZBuckeye
I weigh about 215 and I cranked mine all the way up, for solo or two-up riding.
Old 11-20-2008 | 10:58 AM
first dyna 07's Avatar
first dyna 07
I use a rubber strap with a handle on it , like the oil filter wrench you use and I put it at the base of the shock and tighten the rubber strap on to the lower part of the shock and turn it . It worked great for me . P.S My bike came shock on number 3 and rode it for about 1000 miles that way . Then ajusted them to number 2 and I like it better this way . I am 6' 1" 240 lbs it did not ride as hard .
ducktape98
06-22-2009 06:10 AM
DustMan
06-01-2007 01:08 PM
fendrix
05-10-2007 10:52 PM
supermario
02-20-2007 06:01 PM
06Heritage
07-27-2006 10:34 PM
Quick Reply: Shock adjustment
