Are you supposed to cut this? (Removing stock seat on FXDC)
I'm trying to install my new seat, and I can't get the stock one off for the life of me. I've removed the screw, but the grab-strap is keeping me from removing the seat or anything else, and I can't figure out how to get the thing loose. Am I supposed to just cut the thing off (not like I ever plan on using it)?
Your seat needs to move backward to come off the bike. I fought the strap for quite a bit then realized my sissy bar wouldn't let the seat move back far enough to come off. The strap is a tight fit when done right but it is possible. I use the strap to hold my gloves or glasses from sliding off the seat.
remove phillips screw in rear fender
slide seat back until the tab slides out from under gas tank
rotate seat 45 to 90 degrees to the side
pull seat out from grab strap
remove nut from fender holding on grab strap
reverse to replace.
No need to keep it if you state has no laws about grab straps or you have a sissy bar when you ride 2 up.
If you ride 2 up and have no grab strap and no sissybar.. well lets say if she falls off she'll probably cut you off for a long time if not forever.
reverse to replace.
Received 75,528 Likes
