Winter project
Old 11-11-2008 | 11:17 AM
rockon's Avatar
rockon
Originally Posted by blubob
don't do it! Those badges look horrible!
Old 11-11-2008 | 01:03 PM
dyna rider's Avatar
dyna rider
Thumbs up 200MM Tire
You have to mill down the pulley and cut down the L/H wheel spacer, but if your bike will be at a fab shop they probably already have a milling machine (Bridgeport) and a lathe to cut down the spacer.You do not need another belt. Post pics when done. Good luck !
Old 11-11-2008 | 01:54 PM
JRK5892's Avatar
JRK5892
Originally Posted by imjdoggie
^^^Your bike looks great man, there was actually an article in the local paper (Reading Eagle) about them recently, they put a small block in a crazy looking bike and one of the guys has a bike in the local Museum for the Motorcycle theme they have going on now. I 'll try to see if the article is online. I actually want to put these badges on tell me what you guys think.
I cut my derby and points cover to match for those badges and then never installed the badges!
then did a bit of custom powder coating to tie them in:
Old 11-11-2008 | 03:01 PM
dyna rider's Avatar
dyna rider
Default Badges
Joe- The derby and points covers look outstanding.
Old 11-11-2008 | 05:04 PM
Bobber S's Avatar
Bobber S
Nightster rear end on my street bob
Old 11-11-2008 | 11:08 PM
BluBob's Avatar
BluBob
Could you use your hub and pulley, but just lace that XBones rim onto it?
Old 11-11-2008 | 11:13 PM
anubisss's Avatar
anubisss
Get some mini bullet signals off ebay ($20 or so) and mount then on the side of the fender if possible, and get a sidemount plate with brake light. It all really depends on how much you chop the fender. If you keep the struts or part of them mount the signals there.
Old 11-12-2008 | 07:53 AM
imjdoggie's Avatar
imjdoggie
Good question, hopefully someone will chime in and know the answer. It seems alot easier than milling down the pulley and cutting the spacer.
Old 03-26-2014 | 11:01 AM
darrellbuddy321's Avatar
darrellbuddy321
6th Gear
Hey your bike looks awesome! Would you mind sharing the part numbers for cables you used for your nightster bars?
hddee
02-01-2012 07:34 AM
rowdy82
06-23-2010 08:04 AM
miketedesco
06-23-2009 10:59 PM
Double00Aught
04-01-2009 10:07 PM
Quick Reply: Winter project
