Change inner primary bearing required?
I just bought a used 2006 Dyna Street Bob. After going through some papers that I got with the bike I found this statement:
"An inner primary bearing replacement is required at 15,000 mile intervals."
It goes on to say, "Harley-Davidson has preliminarily determined the inner primary bearing on your 2006 Dyna motorcycle will require replacement at 15,000 mile intervals. The bearing will be replaced by your authorized Harley-Davidson dealer at 15,000 miles and at subsequent 15,000 mile intervals, at no cost to you. This service requirement may change over time as we make improvements and monitor repair trends on 2006 Dyna motorcycles."
Does anyone know about this? Is this still a problem?
I think you will find the majority of the 06 Dyna owners on this site have experienced IPB issues. Mine went out a couple weeks after my factory warranty ended. When I talked to the dealer about replacing it, I showed them the letter from Harley. They pulled my VIN# up on the computer and saw I also had recall work needing to be done on the tranny. They went ahead and replaced the primary bearing at no charge to me. I don't know if they did it because of the letter or because they were already going to be in the cases for the tranny recall work.
Just so you know, Harley later published a letter stating the IPB replacement was no longer needed as outlined in the first letter.
In the service manual, it says to replace every 15k miles though, so I'm confused.. am I supposed to do this or what? I was told late model 06 dyna's, something like if they were manufactured from july or august of 06 and on, they are fine or something along those lines...
So I have a late model Dyna, and mine has been going strong for 18k miles.. do I still need to replace it according to the service manual?
If they will not replace it, wait to see if/when it goes bad. I can't see the need to go to the trouble or expense (on my dime) to replace if it isn't making noise. If an occasion comes up where you are removing the primary cases for other work, replace it while you are in there.
Just my thoughts on this.
