Yet another Derby cover screw question...
Since we have just had a bunch of posts on replacing the derby, and it was fresh in my head, (and since I just got my night train cover in the mail...)
I went ahead and replaced it,...
All good info on those damm T27's, I actually took a torx bit(T27) and ground the tip flat to make sure I wasnt usng any rounded off bit.
I tapped it into each screw with a metal hammer, and used a 1/4 inch ratchet to back them out, all came out extreemly easy, thank goodness.
They were a bit hard to get off the torx bit but better that then stripped right?
I replaced them with Stainless allen screws, but I could not find a small flat washer like was on the T27 screw.
Are those washers necessary?
Thanks, Eric..
Thanks, Eric..
Horseshack
03-18-2011 07:28 PM
