Need Help To Find Braided Sleeve For Oil Cooler Lines
Old 11-01-2008, 03:37 PM
CCPD's Avatar
CCPD
CCPD is offline
Default Need Help To Find Braided Sleeve For Oil Cooler Lines
I did a search and didn't find any good info about braided lines for the oil cooler. I am looking for the black, high temp, braided line like what is already stock on other hoses on my 07 Low Rider. Drag Specialties has Accell braided lines, but not in 5/8. I checked the Dealership, Auto Zone and NAPA with no luck.
Has anyone else put braided lines on the oil cooler hoses and if so what did you use and where did you get it.
Thanks!
Old 11-01-2008, 03:39 PM
Bluesssman's Avatar
Bluesssman
Bluesssman is offline
How about some of those dressup hose kits. Might check Summit Racing.
Old 11-01-2008, 06:14 PM
JRK5892's Avatar
JRK5892
JRK5892 is offline
i use these guys on every build i have to cover all the wires... comes in heat, gas, moisture, you name it they make it to resist or withstand it... have my cables on my bob all wrapped in black!, super fast shipping and great to work wiht, best off they are cheap as hell
http://cableorganizer.com/wire-management/
Old 11-01-2008, 08:51 PM
CCPD's Avatar
CCPD
CCPD is offline
Excellent link! Thanks! Now, does anyone have any idea what kind of heat the oil cooler lines, and engine in that area, give off? The Nylon braiding from that site has a melting point of 302 F. I would think that would be enough for the line, but it's better to be safe and ask first.
Thanks
Old 11-01-2008, 11:28 PM
paulies 07's Avatar
paulies 07
paulies 07 is offline
You might check Earls performance plumbing on the web, been using them for years, excellant quality s/s hoses
Old 11-02-2008, 01:50 AM
JRK5892's Avatar
JRK5892
JRK5892 is offline
ddue your oil lines will get no where near 320... if they do melting the covers will be the least of your worries
Old 11-02-2008, 02:35 AM
CCPD's Avatar
CCPD
CCPD is offline
I figured it would be enough, just needed reassurance. What kind of tape do you use to keep the ends from fraying?
Thanks
Highgrade
02-15-2017 10:02 AM
cruzmisl
07-07-2012 07:21 PM
BillyG0856
06-28-2011 03:50 PM
pavin
11-21-2010 04:56 PM
deadeye
09-09-2009 09:37 PM
Quick Reply: Need Help To Find Braided Sleeve For Oil Cooler Lines
