Photos of my Dyna 'Electra Glide'
The engine guard comes powdercoated gloss black, it's a H-D model for touring models. Since I had installed Softail floorboards, there is a tab for mounting the engine guard that protrudes below the floorboard bracket. Only thing I did different is, I believe on the touring models the upper tab tucks aft of the crossmember on the frame; whereas I just bolted it up forward of the crossmember with the bolt coming through forward from the rocker cover. The fit to my bike was really close given that I have the floorboards, and just took a little "convincing" with a crowbar to line up perfectly!
I'll post a few more photos in a couple of days when I get the passing lamps/turn signal kit installed and the lower fairings.
Also, as someone noted, I should get hard bags. That is also in the works ... I plan to get the old 78-84 style FLH bags and just mount up to the rear fender struts.
Thanks for the kind words fellas!
R/
Priest
Hey xbox, I don't know if Priest had this problem since his is an 05 but the Fat Boy trees do not fit well with the 06 and newer frame. The problem is the bottom bearing on the Fat Boy trees needs to be spaced away from the tree about .150". That leads to more mdifications to the tins or nacelle. I had to oblong the holes in my nacelle to get it to bolt up. That was no problem but it will also have to be done to the light bar if you want to run it as well as the brackets for a windshield or fairing.
Point is if you pay someone to do this it will cost you. If the shop you choose has never come across this it will be on your dime as they scratch their heads trying to make it work.
Looks awsome Priest! Are you going to keep the stock rear fender or switch it out for one from a touring model? I have one from a Road King I'm widening to fit mine. The deeper I get the more I wish I had an 05, looks like it would be a little closer to a "bolt on" set up.
