Black battery band cover
10-22-2008, 10:47 AM
I have a 08 bob and been trying to find a black battery band cover. Does anybody know where I could find it or should I just get it powder coated.
10-22-2008, 11:06 AM
powder coat... or rattle can... if you use Black epoxy paint it is a perfect match to high gloss black powder
I have the same problem, I think I will be giving mine the rattle can treatment.
10-22-2008, 11:08 AM
Quote:
Originally Posted by
JRK5892
What kind of sanding should I do, before I rattle can the battery band, and horn cover.
10-22-2008, 11:49 AM
michaelvs710
You probably won't find a manufacturer that makes one in black... most people just spray paint theirs or have it powdercoated.
10-22-2008, 12:46 PM
i just ruff it up wiht 400 gritt sand paper... i powder coated mine but all my stuff is still boxed up for the move... on the battery box and fuse box i sanded it down to metal, 400 grit, then i shot it with black epoxy appliance paint... PERFECT match! also did my shocks last week... look sick!
10-22-2008, 02:15 PM
I spray painted mine also, it worked great and much cheaper.
10-22-2008, 02:32 PM
if you want durablility the powdercoat should only cost 10-20 bucks.
10-22-2008, 05:30 PM
I sprayed the band on my 08 Fat Bob with wrinkle black and "cured" it with a heat gun. It's an exact match to the factory battery cover.
10-24-2008, 11:22 AM
thanks joe i think i might give the can shot first if it looks bad it will be a cheap fix
