Wide Glide sliders on mid-glide?
I've been running WG tubes on the regular Street Bob sliders. Had an accident that bent the right tube,replaced both tubes and used the original sliders. Right slider is leaking. Tech thinks the slider may have been damaged internally and may have to be replaced if a new seal doesn't fix the problem. In case the one slider has to be replaced I bought a set of chrome sliders from a Harley dealer on e-bay for a hundred ten bucks which is almost a give away. My sliders now are hand polished but not chromed.
Here's the rub. The brake side slider on a WG has a different part number from the brake side on a mid-glide. Right side has same part number. Looking at the parts they appear to be identical. Harley parts guys don't know why there is a difference. Anybody got any thoughts on this?
Good Luck
Tom
Good Luck
Tom
I'd think it would have something to do with the brake mount spacing.
Look up the calipers and see if they are the same or not...or see if there is a different mount.
Maybe the WG has a bigger diameter disc and has to be mounted out further?
Be nice to have them side by side to compare...go to the dealer with a tape measure and start checking it out!
WILL NOT WORK. the spacing to the standoffs where you mount the caliper to are different lengths, so if you use a wdg slider for a narrow glide front end, the caliper will not align right to the rotor. but you can use narrow glide sliders with the wdg front end just need to add spacers. but cant use wdg sliders for a narrow glide front end. jackyl
A straight edge laid across the outer edge of the fender supports aligns with the inner edge of the caliper support on both the WG and SB slider. The measurment from the bottom machined pad on the lower caliper support to the upper edge of the upper fender support bolt hole measures the same. When you hold up the new slider next to the old slider they appear the same. Maybe I'm missing something but I just don't see the physical difference.
Would love to go the the WG trippletrees just not the right time financially for me.
Thanks
Tom
the hole pattern will be the same. but the standoffs are located in a different location on the slider, more towards the wheel and/or the standoffs are thicker or thinner. the wdg slider postions the cailper more towards the wheel, the caipler will be in the same position, but more towards the wheel. if the standoffs are the same thickness. then look down the center of the wdg sliders with the standoffs straight up, then look down the narrow glide slider and you will notice that they are postioned different. jackyl
cgtrigg
03-14-2012 09:43 AM
