transmission issues
transmission issues
i took my 06 superglide to the stealer because my engine was misfiring really bad and the transmission makes weird noises. they told me that the engine had some how gotten out of sync with the trans. they said they need to remove the engine and tranny and resync them. any ideas before i pay them tons of money to do this.
Sounds like BS to me. The only way they are linked is through the primary and even if it slipped a tooth on one of the sprokets because of a loose primary chain, the engine will still turn the tranny. There is no "timing" between the engine and tranny like there is between a crank and cams.
If what you are telling us is correct, they are trying to get money out of you... and they charge a LOT of money to pull a motor and tranny.
How does the transmission whine "at idle???" Whether a motorcycle or car, (a) there's no "synchronization" between engine and transmission; and (b) if the transmission is in neutral or if the transmission is in gear but the clutch is pulled in/depressed, the transmission mainshaft won't even be rotating - so how can it "whine?" Someone is trying to rip you off big time. Get a second and third opinion.
well i just talked to the dealer and they recommended i trade it in. i got pretty mad at them and told them their techs are a bunch of monkeys and their service writer is a crook. i told them i wont trade it in because i love it. so i am going to call HD tomorrow and tell them about my experiences with the dealer
ALL BS!!! Ask them to show you a diagram of how a motor will sync to the tranny... it is gears! they are lie'n I woudl also call MOCO and speak to them about this issue... they have been cracking down on dealers that are ripping people off. HD is starting to get a bad name for service and the aftermarket world is taking the $$ away... SO HD is trying to fix this
I would take your complaint to HD's main office. I had a similar issue with an a-hole dealer that was trying to take me to the bank. Long story shot, HD had this dealer call me the next morning before the sun came up, to see when they could come by and get my bike. They fixed it that day and I was riding home at 5 later that day. Trust me, the MOCO will take your complaint seriously and make this right.
Good Luck!
Justin
Good Luck!
Justin
Ron
