Oil coming out of the air filter????
this is completely untrue...your cylinder head crankcase breathers run though your intake (crankcase breathers).... alot of people will actually re-route then to a catch can or something along those lines to catch that oil before it gets into your intake and sucked back into the motor... before i go on long trips i will use a turkey baster to remove a bit of oil to compensate for the oil expansion as it gets hot... you will find alot of people do this... just pull a bit of oil out you just have a touch to much in there...
Dealer says it's not really anything to worry about...
LDUltra
08-19-2008 06:53 PM
