Gunna do it. Putting a springer front end! Need help..
Old 10-10-2008 | 03:56 PM
rdondes's Avatar
rdondes
I have the same question that Rockon has...
Old 10-10-2008 | 04:06 PM
rounder's Avatar
rounder
Originally Posted by AdrianVall
Thanks for the help guys. I figured it would probaly cost somewhere around the $800 mark for what I want to do with it.
Question though..
Could I re-use the same rotor since the front rim will be laced? And I need a new caliper, correct?
And the headlight.. could I reuse the stock headlight? I would imagine I would just need to get a different mounting bracket, correct? Anything that I can save money on, I will try. I'm hoping to sell the stock front end once I get everything together to off set the cost of the springer a bit.
I'll keep you guys updated. Thanks for the pics by the way..
caliper yes.. depending on the year the springer is fashioned after you will need to get a different rotor due to different diameters between certain eras..
also remember new handlebars and risers the distance between the risers is different on a springer... you may be able to use headlight with just a mounting for a springer.
also unless you are 100% certain you will ride without a fender make sure the front allows for fender installation.
Old 10-10-2008 | 04:34 PM
AdrianVall's Avatar
AdrianVall
Kansas: I didn't see a price on those front ends.. what am I looking at if I go with DNA? Demons cycles might be the cheapest alternative, but if there's anything better, please let me know. Thanks man!
Old 10-13-2008 | 09:29 PM
AdrianVall's Avatar
AdrianVall
Bump!
Lee.moore1
11-09-2016 05:08 PM
coma
12-08-2015 12:58 PM
ClodeV
01-06-2014 06:49 PM
stover954rr
04-04-2013 05:23 AM
reedc89
05-05-2011 01:18 PM
