Bled the Fr brakes...now only half the amount of brake!???
Old 10-08-2008 | 01:55 PM
118811fh's Avatar
118811fh
Default Bled the Fr brakes...now only half the amount of brake!???
I rerouted my brake cable and thought I should bleed the system while i there
I even evacuated the line........after about 20 minutes of pumping the system I finally achieved only 1/2 the brake at the lever I had previously.
Anyone have any ideas for me?
Thanks Guy's
Old 10-08-2008 | 02:06 PM
fiend138's Avatar
fiend138
Keep going, those master cylinder don’t move that much fluid so it take a while to get all of the air out.
Old 10-08-2008 | 02:21 PM
JRK5892's Avatar
JRK5892
takes a WHILE about 1/2 hour... what kind of bleeder are you useing? try speed bleeders or a mini vac gets it done FAST
Old 10-08-2008 | 03:03 PM
rounder's Avatar
rounder
on my new line we went through a 12 pack to get it bled right... about an hour... just keep at it or get a mitivac or something...
Old 10-08-2008 | 03:22 PM
Slipstrm's Avatar
Slipstrm
I use those syringes that you inject flavoring into Turkey's with, put a clear piece of tubing on them that will fit over the bleeder screw..
I pull the fluid from the Caliper side, just keep the reservoir full and it takes about 5 minutes.
You can push and pull the fluid back and forth to get all the air out.
Old 10-08-2008 | 03:49 PM
07bobber's Avatar
07bobber
When i changed the front it took me about 10 mins....but i had someone help me
Old 10-08-2008 | 08:54 PM
wkdavistx's Avatar
wkdavistx
If you will tap or shake the line continually it will break the air bubbles free from the inside of the line and they will float to the top. When you apply the brake lever you'll see tiny bubble come up through the reservoir. This is, of course, after you have pushed all the old fluid out and get new fluid to come out of the caliper.
Ride safe!
Old 10-08-2008 | 09:38 PM
Baeseman1's Avatar
Baeseman1
Originally Posted by wkdavistx
If you tap or shake the line continually it will break the air bubbles free from the inside of the line and they will float to the top. When you apply the brake lever you'll see tiny bubble come up through the reservoir.
That worked for me...
Old 10-09-2008 | 06:39 AM
8541hog's Avatar
8541hog
The front brakes can be very frustrating, especially if you are using DOT 5 as it tends to hold air bubbles in suspension. The best thing for front is a vacuum type bleeder or try the speed bleeders.
One other note, on mine the handle felt very mushy until I rolled the bike back down my driveway and hit the brakes a few times, that stiffened it right up.
Old 10-09-2008 | 07:35 AM
Mascman's Avatar
Mascman
Were you pumping it slowly or quickly?
The slow method works better on this system.
When I did mine, I just grabbed the lever, pumped it quickly, opened the bleeder and repeated. It wasn't working too well.
It wasn't untill I started to squeeze slowly that I got a good feel at athe lever.
biketroll
06-02-2021 11:00 AM
eric2011Deluxe
04-01-2012 02:15 AM
WARG
07-13-2008 04:04 PM
twstdharley
26
07-04-2007 12:14 AM
braggster
05-20-2007 10:51 AM
Quick Reply: Bled the Fr brakes...now only half the amount of brake!???
