Side Plates for 03 Dyna Wide Glide?
I used standard dyna detachable sideplates on my 03 WG with bags. The bags I had were HD and made for the WG with recesses for the relocated turn signals. They required that the signals be moved with or without the detachable sideplates so I just substituted the docking points for the spacers that came with the bags. The signals simply move to the rearmost hole in the fender strut. Worked out great for me.
My 03 WG has These side plates 53870-01A and harley saddle bags. Both are quick release. I just mounted the side plates as per the instructions then I took them off and put on my saddle bag mounts (barebacks) and then notched the quick release side plates. If you look, I had to make a spacer for the rear bare back mount to push it out as far as the front one.
Here are some pics
Here are some pics
