**DYNO SHEETS* and/or *1/4 MILE TICKETS**
Old 03-03-2019, 08:45 AM
sharkey's Avatar
sharkey
sharkey is offline
SE 103 pistons/cylinders, S&S 583 EZ start cams, RB Racing Black Hole. A solo touring mount with satisfactory torque in the range I ride most.
Gearhead88 (09-12-2020)
  #292
Old 03-03-2019, 08:50 AM
sharkey's Avatar
sharkey
sharkey is offline
HQ 103 with his heads, pistons and 0033 cams. Khrome Works 2" 2-2 exhaust. SE 51CV carb. 100+ ft lbs from 2200-5800 rpm made this 608 lb (wet weight) FXDXT a blast to ride
  #293
Old 04-03-2019, 03:42 PM
rons73's Avatar
rons73
rons73 is offline
09 Dyna Street Bob
S&S 110 Kit
Heads ported / machined by Dave Mackie
Compression 10.7
HPI 55mm TB w/ 5.3 gps injectors
Woods TW-8-6 cams
Thrashin AR 2-1 Exhaust
  #294
Old 04-04-2019, 08:25 AM
Heinlo5166's Avatar
Heinlo5166
Heinlo5166 is offline
1st Gear
My dyno on my 117 m8
Originally Posted by mud
post up your dyno sheets and/or 1/4 mile tickets.
wanna see the *actual paper*, not just typing
then also, helpful to describe the modifications
  #295
Old 12-07-2019, 12:32 PM
Z'Stein's Avatar
Z'Stein
Z'Stein is offline
I'm looking for someone that knows their way around the SE 110 Heads. I have a 2017 Softail Slim S, and I'm upgrading to the SE 117 Street Performance kit. I won't be using the SE 259e cam that comes with the kit. Instead I will be using the 9B-6 cams from Wood Performance and the compression should come in about 11.5:1. I'm trying to make or get as close to 150 hp as possible and I doubt if I can get there with the heads in their stock form. Does anyone know who or where can I send my heads to have them ported to support 150 hp? Thanks
  #296
Old 12-07-2019, 04:35 PM
johnwesley's Avatar
johnwesley
johnwesley is offline
Who Larry would be a good guy to talk to. Also star racing knows their stuff and could let you know what needed for 150
this is 140 out of 113
https://www.starracing.com/tk-113-upgrade
Z'Stein (12-07-2019)
  #297
Old 12-08-2019, 12:15 PM
TOE_CUTTER's Avatar
TOE_CUTTER
TOE_CUTTER is offline
If I may suggest, I would start your own thread. Next, I would not suggest that you stay with the stock rotating assembly. The design of the small end will score, and you’ll have to re-do your motor. Go with a S&S rotating assembly, timken your cases, and use S&S cylinders. Make a 124, and you will have no issues getting a bulletproof 150+ hp. I have just gone down this path, and I would have saved a buttload of money if I would have gone with the 124 to begin with. Again, IMO.
Dave
  #298
Old 12-08-2019, 12:43 PM
Z'Stein's Avatar
Z'Stein
Z'Stein is offline
Dave
Thanks Dave.
  #299
Old 09-10-2020, 04:10 PM
jlb0038's Avatar
jlb0038
jlb0038 is offline
Just got my bike dyno'd yesterday. I know I'm losing some with the pipes, but they sound awesome. Not sure I wanna give up the sound for a few extra. Before the tune, the tuner said that they had a conservative dyno, so the numbers could be lower than another dyno. Don't know but it runs great. I had the Target Tune on before and had run a few auto tune sessions with a canned map (sorry don't have that sheet), only picked up a few horsepower and a couple lbs of torque, but the responsiveness much better.
2106 Dyna Street Bob 103
Powervision
Andrews 48h cams
Bassani Radial Sweepers
  #300
Old 09-14-2020, 10:19 AM
brownie4412's Avatar
brownie4412
brownie4412 is offline
Received 1,032 Likes on 600 Posts
TONS of fun. I find myself frequently bringing the front wheel up without dumping the clutch.
Quick Reply: **DYNO SHEETS* and/or *1/4 MILE TICKETS**
