**DYNO SHEETS* and/or *1/4 MILE TICKETS**
Old 01-12-2016, 09:30 AM
BocaBob's Avatar
BocaBob
BocaBob is offline
5th Gear
Just got her back yesterday, changed out stock air cleaner for screaming eagle, replaced screaming eagle night sticks for Crusher mellow slip on's. Also found a fuel leak internal between pump and petcock. No motor work, just adjustments. This is a 110 screaming eagle motor swap before I purchased it. The Dealer did a base 110 down load that really didn't work well. Not enough intake air, and closed exhaust wouldn't let heat out quick enough. This is a air cooled mother not water. I am also going to put a oil colder on her to try to get more heat out of the engine. Also added a Direct Link Tuner. Rode over 250 miles yesterday on $6.
Extreamly pleased and looking forward to her future
  #242
Old 01-24-2016, 10:56 AM
nottaway's Avatar
nottaway
nottaway is offline
subscribed
  #243
Old 01-28-2016, 02:39 PM
sleazy rider's Avatar
sleazy rider
sleazy rider is offline
Just about what I expected. 99.3 hp and 113 lb/ft of torque. A little more dialing in with the spark advance and it'll hit 100/115.
  #244
Old 02-04-2016, 05:07 PM
yooperhog's Avatar
yooperhog
yooperhog is offline
Ok. 2010 FLHTP. 103
stock heads and pistons
v and h breather
v and h pro pipe with modified baffle
listed as fat cat due to the non stock baffle
wood 777 and pv tune at FM
  #245
Old 02-05-2016, 03:50 PM
gi_king_ken's Avatar
gi_king_ken
gi_king_ken is offline
Here's the dyno for my old bike after I put in my cams.
2001 fxdxt
Drag pipes. Unknown company. Wrapped
SE breather. SE Wires.
Stock 88
TW 3 7 G gear cams.
Max HP 80.81 max torque 86.04
  #246
Old 02-19-2016, 01:05 PM
JMP671's Avatar
JMP671
JMP671 is offline
5th Gear
2014 FLHTK
106CI w/ S&S internals
585EZ cams
stage street port (local porter)
SE 58mm SE air intake
MGS TD
97.12 HP
112.47 TQ
dyno sheet is attached bike runs solid with over 30,000 miles since the build with no issues.
Attached Thumbnails **DYNO SHEETS* and/or *1/4 MILE TICKETS**-2014-flh-106-tc-stage-2-mgstd-585-cam.jpg
  #247
Old 02-19-2016, 01:31 PM
JMP671's Avatar
JMP671
JMP671 is offline
5th Gear
Sorry newbie mistake didn't realize it was for dyna models. oops
  #248
Old 02-20-2016, 06:54 AM
Buck Knife's Avatar
Buck Knife
Buck Knife is offline
Default Dyno sheet
Revolution Performance 107"
S&S 583 Cams
S&S adj. pushrods and lifters
Stock heads and throttle body "massaged"
  #249
Old 03-25-2016, 05:53 PM
MichaelSG's Avatar
MichaelSG
MichaelSG is offline
  #250
Old 03-25-2016, 07:12 PM
Crazy's Avatar
Crazy
Crazy is offline
Received 1,605 Likes on 845 Posts
S&S 583 Cams
Very nice. Who massaged the heads and TB?
Quick Reply: **DYNO SHEETS* and/or *1/4 MILE TICKETS**
