fxd tank swap to a fxdc fat bob tank
Old 10-04-2008, 11:00 AM
davidray's Avatar
davidray
davidray is offline
thanks armybrat for the list,had to take the bike into the local shop.and was talking to them about it we were thinking it was going to run some where around a grand for the conversion less the tank which i already have. im wondering how much diffrent the parts list would be for the fxdc tank i need parts for and the street bob conversion you did.i know the console would be. also i was going to ask how did the wiring harnees do i see none on your list so do we have enough for the tank swap or did you have to wire it your self
Old 10-04-2008, 11:12 AM
armybrat02's Avatar
armybrat02
armybrat02 is offline
the only wire that I had to mess with was the ones for the indicator lights b/c they had a different plug to connect them to the wire harness. For the ignition you will need to add some wire to get it out of the neck and re-run the wires, should not be hard. The only things that I can see that are different would be the speedo its the 5" one, the ignition will have to be moved from the neck to the tank and the led panel is different. I am going to move the ignition soon like some of the other people on here have done. no special tools if you want to go to the SB tank but to move the ignition there is a special tool to take it out of the neck some people have posted on how to do it with out using the tool from hd. its like $50 from the steeler.
Kev_England
12-10-2020 01:22 PM
Knucklehead15
01-10-2011 06:28 PM
FiremanQ14
11-14-2010 07:25 PM
shrini23
11-08-2009 06:01 PM
songsmith
03-26-2008 09:45 PM
Quick Reply: fxd tank swap to a fxdc fat bob tank
