MAPs,FUELPAK,DYNA JET, PCIII !!!???HELP!!!!!!!
ok i bought an 04 lowrider from a guy in town here that had purchased it from a dealer in Phx. (used) EFI nice bike i love it Problem is: ever since i have owned it it has ran RICH when it eas purchased from the dealer it had a screamin eagle air cleaner and a thunderheader 2 into 1. since i have installed V&H Straightshots, still runs rich, How do I know if it has had a stage 1 mod or what? Thanks and please what do you suggest?
If you have any kinda of tuner/device plugged in between your ecm and the stock ecm plug. I think, not for sure, the sert is the only device that does not stay plugged into your bike, it just adjusts your stock ecm. The others overide your ecm and tell it to do certain things. That would be your best bet to figure if there is a tuner installed.
Since you say your running rich i am going to assume you have a tuner. As the bikes, now days, come from the factory running really lean (THANKS EPA! ). Then when you add more air this leans the mix out more, thus the need for a fuel tuner to richen the mix back up and give you better performance.
If the bike is truely running rich then it probably has a a PC or fuel pak or some other fuel management system. It just needs to get tuned either on a dyno and by loading the correct MAP. 1st Do a internet search for stage 1's, take your cover and filter off to verify what you have. Most common stage 1 upgrades are Screaming eagle and Arleen Ness; both look very similar. 2nd do a search for power commander and fuel pak, take your seat off to verify what you have if any. Power commander has all the software and many MAPs on there site to assist with your rich problem, but you must have a notebook to load software; if you verify you have a fuel pak call vance and hunes and I'm sure they can help you out. I hope this helps.
Sad that y'all missed the most obvious and easiest. One guy suggested "just take it to have it dyno'ed." Initially is bad advice. Let the guy visually find the add-on device. if he cannot locate it, then contact previous owner if possible. If that fails, then move on to other means. If it has a SERT, wouldn't HD have a record of it? I'd say contact HD to see what they show in their records. Also free, except the phone call.
Also, if it's a 2004, wouldn't that be before the big EPA push we have today? I don't think they were as strict with HD as they are now so you can't even assume that.
SGT Rock TN
06-16-2014 09:28 PM
