LED gas guage
RE: LED gas guage
You need to run a wire from the gauge up to the speedo. Otherwise it is installing wires in a connector that is provided by the kit. This connector plugs in with the origional one You might need a sewing needle to remove the wire in the speedo from the connector. There is a tab that hold's the wire in the connectors. You need to release this tab to remove th old wire and install your new wire. I don't recall if you had to install the wire ends or if they where allready installed. The direction's where pretty good.
RE: LED gas guage
There is a tube that the wires run through that goes through the tank. All you have to do is disconnect from the harness pull straight up on analog gauge pulling the wires through the tube. Then you will feed wires of new LED gauge back through the tube and re-connect. Shouldn't take 15 minutes.
RE: LED gas guage
Thanks Dynamite, it came in yesterday and I read the instructions ( I hate having to do that). I really didn't have time to install it because I had to put the new seat, side rails and sissy bar for my wife before we went out to eat. I've spent 700.00 on add-ons and most of it is just to make her comfy. It's amazing what I do for her...
Anyway, I'll do it when I get off work today, it didn't look like there is much to it.
Thanks
Caston
Thanks
Caston
campdreamer47
11-16-2005 01:03 AM
