Help with front brake cable.
I put a set of handle bars on my 07 lowrider that are 2 inches taller and have 2 inches more pull back,everything fit beautiful except the front brake cable,I need a little help finding a 48 inch brake cable and the 4 plastic clips that hold the cables to the bars they h
just go in the drilled holes,but mine are not reuseable.any help on a url would be a lot of help,and what size are they,10mm 0r 12mm, thanks in advance.
get those clips for the external wiring at the local H-D dealer.
crap I thought this read clutch cable..... anyways goodridge makes some nice cables for your ride that will work ... just get the size you need...
oh fwiw I have a 42" brake cable and it is too long for the mini apes so I doubt your gonna need 48" of cable
