Tire Question
Tire Question
First off I searched the forum, too many non related topics came up, I found today that my front tire was cracking in between the grooves on the side of the tire, had the tire replaced, the only difference in the old and new tire is that it is not a Harley sidewall, we started with 34psi, rode the bike, the front tire felt flat, added 2 psi, rode again, same result, kept increasing the pressure till it was at 40psi, it that too much? it doesn't feel flat anymore, my manual says 30psi, no way to ride it with that little of pressure. On a side note the only link that I could find about the pressure was in the Sportster forum, I am including the link. Any advice is appreciated.
https://www.hdforums.com/forum/showt...=tire+pressure
The pressures on the sidewall are for MAX tire pressure under MAX load. It's not the RECOMMENDED pressure. The correct tire pressure for any vehicle is found in the owner's manual, or on a decal on the vehicle placed there by the manufacturer.
I have metzelers and they are run at 40 front 42 rear... my old 19 inch dunlop was 30 front 36 rear.... If you do not have a stock tire anymore then you will need to change pressure for that specific tire...
You said the sidewall is not H-D. What does that mean? You have a dunlop that does not say H-D on it? If so, the sidewalls also could be a different firmness allowing for different feel when properly inflated...
http://www.dunlopmotorcycle.com/fitmentguide.asp
30 psi loaded...
