FXD Speedo in FXDB Console?
Yeah ... think I may just take it easy until I can find the FXDB/FXDL tank; go with the FXDB dash and re-use my speedo.
Just saw a FXDB tank on fleabay ...
Mostly it is just to get the speedo off the bars. I've gotten a FLST front end and I am going to go with the nacelle. It has a cover that goes over the riser. Sure, I could just leave it as is and dispense with the riser cover ... probably will in the short run.
I've seen a few of the Dakota Digital speedos and they're nice; but also can be a little pricey. Part of my motivation is to not spend a fortune ... my better half and I don't exactly see eye to eye on "discretionary" expenditures on my bike. So, if I can do it without breaking the bank, all the better.
Priest -
Been following your posts where you put up pics of the new front end - very cool.
Look forward to seeing the final product.
I agree with rounder - the SB tank and dash is the way to go.
I looked at the adapter ring for a few seconds and realized - just as he stated - that it would not look right.
Good luck finding a tank - i've seen st bob tanks go on ebay for reasonable $ - but as I mentioned - patience is required.
Remember - an FXDL tank will work as well.
At one point I thought I could take my speedo off my handlebar riser and move it to the mirror with Custom Cycle Control Systems LED speedo and idiot lights in the mirror.
The full set-up has slim line control housings for the switches and brake reservoir internal to the handlebar. All clutch, brake and throttle cables and lines are routed internally as is the wiring ... a really clean solution, but costs a couple grand or so.
Maybe if I hit the jackpot or the lottery ... else, I'll take my time and try to accumulate the FXDB tank/console conversion on the cheap.
R/
Priest
R/
Priest
felipevalle
02-28-2014 05:07 AM
Foxster
05-27-2010 08:49 AM
