For the Fab Savy Guys
Old 09-15-2008, 05:21 PM
mud's Avatar
mud
mud is offline
muderator
Received 9,109 Likes on 2,119 Posts
Originally Posted by CK Bobber
Mud,
Nice!!! That looks like it would work perfect......
Only problem left is to fill in the hole left by the current taillight.
Mascman's idea with the rivets might work for this,
Hog's plate looks like it would fit snug enough
to cover the hole if we give it something to mount to.
Yessir, and like I say, until I have the parts in hand,
not positive what direction to follow.
Definitely can be done.
Mud, I think this would work great with that bracket/plate mount and be really easy.
http://cgi.ebay.com/ebaymotors/Harle...mZ130255324948
yeah, looks good in the picture.
And, like you said earlier -
would probably look even better with the mini-bullet sigs
mud
  #32
Old 09-16-2008, 10:11 AM
CK Bobber's Avatar
CK Bobber
CK Bobber is offline
Default Light
I'll go ahead and grab up that light, once I get it, I'll send it your way. How do I get the plate you showed??
  #33
Old 09-16-2008, 10:19 AM
CK Bobber's Avatar
CK Bobber
Default Light
Light bought.... Should be here in a few days....
  #34
Old 09-16-2008, 10:25 AM
HOGRIDA_06's Avatar
HOGRIDA_06
HOGRIDA_06 is offline
I've been real busy lately so I haven't offered any help.
Mud....If you need a bracket burned out just get me some dimensions and I'll get it out to ya.
  #35
Old 09-16-2008, 10:35 AM
mud's Avatar
mud
mud is offline
muderator
I have that on the mudGlide.
I'll use it to mockup and see what needs to
be modified on it to make this work.
Then, I will get with HOGRIDA and see about a modified version,
if need be.
mud........
  #36
Old 09-16-2008, 10:36 AM
mud's Avatar
mud
mud is offline
muderator
I'll check it out Brian.
Then I'll get with you.
mud
  #37
Old 09-16-2008, 01:19 PM
CK Bobber's Avatar
CK Bobber
Default Plate Frame
Right on guys, now we're rolling It looks like that thing will almost work perfect, just flip the inspection tab to the top and straighten it up a little then drill a couple of holes to match the light when we get it..... Only diff. may be the curve lower down on the fender as this will mount where the light goes now.
CK
  #38
Old 09-16-2008, 02:27 PM
JRK5892's Avatar
JRK5892
JRK5892 is offline
now this is why the forum is so great!
  #39
Old 09-16-2008, 02:31 PM
CK Bobber's Avatar
CK Bobber
Cool Forum
Agreed Joe!!!
  #40
Old 09-17-2008, 10:33 AM
Mascman's Avatar
Mascman
Mascman is offline
IMO, you should have gotten the light/plate holder combo...not the single light. Then just plug the holes from the stock plate.
When you remove the stock light, you will have mounting points to use in the cutout.
Just bolt a piece in there and drill into it to mount your new light/plate...quick and easy.
I'm guessing you are keeping the plate in the same location, but laying it down? If so, I'd get a nice wrap-around style.
I was thinking it would look like mine if you bought the combo...just leaving off the bottom light that I have.
Let's get a P-shopped mock up from MUD to get us all on track!
Quick Reply: For the Fab Savy Guys
