Important Threads-Best of Dyna
Old 09-10-2008 | 05:51 PM
JRK5892's Avatar
JRK5892
Default Important Threads-Best of Dyna
Guys i know that IceCaps did this a while back but i have been saving it and adding on to it... here you go! (this list is one i have kept for myself but there is alot there)
Forum links
Bushing how to
https://www.hdforums.com/forum/dyna-glide-models/263272-riser-bushing-how-to.html
Bottle opener how to
https://www.hdforums.com/forum/dyna-glide-models/263277-how-to-beer-bottle-opener.html
Duel disk brakes:
https://www.hdforums.com/m_3632699/tm.htm
https://www.hdforums.com/forum/dyna-glide-models/266574-dual-brakes-on-street-bob-fast-straight-no-fade.html
Dual Disc Brembo calipers on a Dyna
https://www.hdforums.com/forum/dyna-...on-a-dyna.html
Sportster tank on dyna
https://www.hdforums.com/forum/dyna-...-for-dyna.html
Cams:
https://www.hdforums.com/m_3634982/tm.htm
https://www.hdforums.com/m_2066227/tm.htm
https://www.hdforums.com/m_2318998/tm.htm
https://www.hdforums.com/m_3624153/tm.htm
https://www.hdforums.com/m_3584042/tm.htm
https://www.hdforums.com/m_3574448/tm.htm
https://www.hdforums.com/forum/dyna-glide-models/274967-cam-and-air-cleaner-thoughts.html
Floor boards:
https://www.hdforums.com/m_3358319/mpage_1/key_/tm.htm
Extra Lighting:
https://www.hdforums.com/m_3549132/tm.htm
Best solo seat:
http://www.HDForums.com/m_2971212/tm.htm
http://www.HDForums.com/m_1743730/tm.htm
http://www.HDForums.com/m_1531544/tm.htm
checking spokes
https://www.hdforums.com/forum/dyna-glide-models/270271-how-to-check-wheel-spokes.html
EFI Recalibration
http://www.harley-davidson-forum.net...ead.php?t=7227
Fork boots/gaiters:
http://www.HDForums.com/m_2907787/tm.htm
http://www.HDForums.com/m_1002152/tm.htm
Floor boards on dyna
https://www.hdforums.com/forum/dyna-glide-models/271723-fxdp-floorboards-on-06-later-dyna.html
LED’S: (pics)
https://www.hdforums.com/forum/softail-models/271952-light-me-up.html
Stem nut washer replacement
https://www.hdforums.com/forum/showt...87#post3795587
Fall away test
https://www.hdforums.com/forum/dyna-glide-models/272983-fall-away-test.html
Scratch removal
https://www.hdforums.com/forum/dyna-glide-models/274991-vivid-black.html
Suspension/Shock mods/lowering:
http://www.HDForums.com/m_986458/tm.htm
http://www.HDForums.com/m_1802894/tm.htm
http://www.HDForums.com/m_2252964/tm.htm
http://www.HDForums.com/m_1822088/tm.htm
Tire locations to buy:
https://www.hdforums.com/forum/showt...45#post3792345
Tach install:
https://www.hdforums.com/m_3626374/tm.htm
http://www.shareaproject.com/pages/i...i,2354,00.html
https://www.hdforums.com/m_2877668/tm.htm
https://www.hdforums.com/forum/dyna-glide-models/266756-mini-tach-installed-on-fxdci.html
https://www.hdforums.com/m_2750573/tm.htm
Low rider dash tach install w/ idiot lights
Deuce Wheel:
https://www.hdforums.com/m_813473/tm.htm
https://www.hdforums.com/m_958300/tm.htm
https://www.hdforums.com/m_863737/tm.htm
https://www.hdforums.com/m_833970/tm.htm
Do-Rag Guidance
https://www.hdforums.com/m_1944738/tm.htm
Dyna vibration:
https://www.hdforums.com/m_1005462/tm.htm
https://www.hdforums.com/m_3496437/tm.htm
Exhaust Pictures:
https://www.hdforums.com/m_797869/tm.htm
Exhaust gasket replacement
https://www.hdforums.com/forum/dyna-glide-models/264206-exhaust-gasket-questions.html
Forward controls install:
https://www.hdforums.com/m_2339042/tm.htm
https://www.hdforums.com/m_613252/tm.htm
https://www.hdforums.com/m_576946/tm.htm
Fuel Management(SERT, PC-III, Thundermax, ect.):
http://www.nightrider.com/biketech/m...i_upgrades.htm
https://www.hdforums.com/m_2763702/tm.htm \\;- Trotter Thread
https://www.hdforums.com/m_1420193/tm.htm \\;- PhilM - DTT
https://www.hdforums.com/m_180308/tm.htm \\;- Poll
https://www.hdforums.com/m_2564296/tm.htm
https://www.hdforums.com/m_1723575/tm.htm
https://www.hdforums.com/m_1597567/tm.htm
https://www.hdforums.com/m_980076/tm.htm
https://www.hdforums.com/m_2792381/tm.htm
Garage door opener
http://www.shareaproject.com/pages/p...,p,208,00.html
https://www.hdforums.com/forum/showt...=127027&page=3
GPS
https://www.hdforums.com/forum/showt...=266073&page=2
https://www.hdforums.com/forum/sportster-models/263038-gps-on-sportster-pics.html
Inner primary bearing:
https://www.hdforums.com/m_3609254/tm.htm
https://www.hdforums.com/m_1781139/tm.htm
https://www.hdforums.com/m_2540619/tm.htm
https://www.hdforums.com/m_2269574/tm.htm
https://www.hdforums.com/m_1696586/tm.htm
Little hole in front fender:
https://www.hdforums.com/m_2395589/tm.htm
https://www.hdforums.com/m_1960563/tm.htm
Holes in rear fender:
https://www.hdforums.com/m_2750651/tm.htm
Seat scratching from passenger seat
https://www.hdforums.com/forum/dyna-glide-models/266024-prevent-seat-scratching.html
Seat pictures:
https://www.hdforums.com/m_798151/tm.htm
https://www.hdforums.com/forum/dyna-glide-models/270877-le-pera-silhouette-or-bare-bones.html
Shorter kick stand
https://www.hdforums.com/m_2546488/m...tm.htm#3270218
Rear air shocks for Dyna:
https://www.hdforums.com/m_1972403/tm.htm
https://www.hdforums.com/m_2445877/tm.htm
https://www.hdforums.com/m_2372126/tm.htm
https://www.hdforums.com/m_3388111/m...tm.htm#3689316
https://www.hdforums.com/m_3577130/tm.htm
Recommended air pressures
0-10 lbs for a 150-lb to 200-lb rider.
5-15 lbs for a 200-lb to 250-lb rider.
20-25 lbs for a rider with passenger.
FL air preload rear suspension range is 0-35 lbs of pressure.
FLHRS and FLXH low-profile shocks are 0-50 lbs max.
Phone numbers for shocks
https://www.hdforums.com/forum/showt...=266506&page=2
Removing reflectors:
https://www.hdforums.com/m_2863606/tm.htm
https://www.hdforums.com/m_2050477/tm.htm
https://www.hdforums.com/m_2579621/tm.htm
https://www.hdforums.com/m_1744279/tm.htm
Rotor/Stator:
https://www.hdforums.com/m_1889748/tm.htm
Superglide speedo relocation
https://www.hdforums.com/m_671689/tm.htm
21” wheel
https://www.hdforums.com/m_2698051/tm.htm
https://www.hdforums.com/m_1529029/tm.htm
https://www.hdforums.com/m_2790021/tm.htm
https://www.hdforums.com/m_1094755/tm.htm
Wiring extension for apes:
HD Wire Extension Kit 72137-03
http://www.designsbynovello.net/
https://www.hdforums.com/m_1328001/tm.htm - Step by Step
https://www.hdforums.com/m_1180682/tm.htm
https://www.hdforums.com/m_1839302/tm.htm
Installing APE’s
https://www.hdforums.com/forum/dyna-glide-models/88710-my-ape-install.html
https://www.hdforums.com/forum/showthread.php?t=88710
Internal wiring bars
https://www.hdforums.com/forum/dyna-glide-models/14129-evolved-to-the-apes-done-thanks-new-pics.html
https://www.hdforums.com/forum/dyna-glide-models/68079-how-to-do-handlebar-internal-wiring.html
ext: http://www.jpcycles.com/productgroup...9-9D98ED920065
What saddlebags without turn signal relocation:
https://www.hdforums.com/m_298019/tm.htm
https://www.hdforums.com/m_2298730/tm.htm
https://www.hdforums.com/m_1172037/tm.htm
Wide tire kit:
https://www.hdforums.com/m_3596624/tm.htm
https://www.hdforums.com/m_2952015/tm.htm
https://www.hdforums.com/m_2914836/tm.htm
https://www.hdforums.com/m_2642795/tm.htm
Windshield buffeting:
https://www.hdforums.com/m_2363828/tm.htm
https://www.hdforums.com/m_868000/tm.htm
Making your own side mount plate
https://www.hdforums.com/m_2284594/tm.htm
How to check diagnostic codes
https://www.hdforums.com/forum/dyna-glide-models/264270-check-engine-light.html
https://www.hdforums.com/m_2293229/tm.htm
https://www.hdforums.com/forum/dyna-glide-models/139328-identify-trouble-codes-and-clear-them.html
Horn relocation
https://www.hdforums.com/m_1212381/m...tm.htm#3639126
Wire wrap & hot topper
https://www.hdforums.com/forum/dyna-glide-models/263432-cheap-wire-covers-and-hot-toppers.html
Engine mounts balancing
https://www.hdforums.com/forum/dyna-glide-models/264143-front-end-wobble-on-decel-any-suggestions.html
Motorcycle lift:
https://www.hdforums.com/forum/showt...=1#post3732596
sporty speedo relocation
https://www.hdforums.com/forum/sportster-models/268537-speedo-relocating.html
Tank Dents
https://www.hdforums.com/forum/showt...25#post3769025
battery tender
https://www.hdforums.com/forum/dyna-glide-models/269116-want-a-cheap-battery-tender.html
Wood bike stand
https://www.hdforums.com/forum/showt...95#post3790995
passanger seat protection (scratching)
https://www.hdforums.com/forum/showthread.php?t=266024
“sickest” bob
https://www.hdforums.com/forum/dyna-glide-models/269155-who-has-the-sickest-bob.html
Links from FXD2003rider
H-D instruction sheets database
https://www.hdforums.com/forum/dyna-...-database.html
Dyna Models Wiring Diagram Links Index
https://www.hdforums.com/forum/dyna-...nks-index.html
dyna models metric sizes database
128AUTO ignition relocation
https://www.hdforums.com/forum/dyna-...ld-w-pics.html
How to: fairing and saddle bags
https://www.hdforums.com/forum/dyna-...-and-bags.html
shimmed front motor mount
https://www.hdforums.com/forum/dyna-...today-wow.html
GPS mount - by 128auto
https://www.hdforums.com/forum/dyna-...-pictures.html
FUEL line repair - Formula
https://www.hdforums.com/forum/dyna-...fuel-line.html
Cam in stall - 128auto
https://www.hdforums.com/forum/dyna-...nsruction.html
Horn relocation - 128auto
https://www.hdforums.com/forum/dyna-...on-w-pics.html
06 Street bob IPB bearing, stator, and 30t Sprocket - Gatone13
https://www.hdforums.com/forum/dyna-...-sprocket.html
floorboards for under $100 with heel toe shifter - JRK5892
https://www.hdforums.com/forum/dyna-...der-100-a.html
Old 06-10-2011 | 05:39 PM
DSnoopy's Avatar
DSnoopy
Bump for the best thread reference ever! Add to favorites!
Old 06-10-2011 | 05:54 PM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
I'm making this a Sticky thread. Good job.
Old 06-11-2011 | 11:56 AM
sian0120's Avatar
sian0120
wow.... the best..
Old 06-11-2011 | 03:21 PM
fenderzig's Avatar
fenderzig
Great place to start with the forum. Most likely 90% of newb questions can be answered right here so we don't need to see more exhaust threads, forward control install threads, ape hanger threads, etc...
Great idea!
Old 06-12-2011 | 08:37 AM
stilup's Avatar
stilup
Best post ever! Thanks.
Old 06-12-2011 | 09:16 AM
128auto's Avatar
128auto
Very sticky, thx!
Old 06-12-2011 | 08:14 PM
EricInNCa's Avatar
EricInNCa
Lots of information provided. Certainly a good place to reference... Nice job!
Old 06-12-2011 | 09:52 PM
emerican19's Avatar
emerican19
Awesome, glad someone took the time to do this. Bookmarked fo' sho.
Old 06-18-2011 | 10:50 PM
Reaper_ggy's Avatar
Reaper_ggy
Hey JRK5892 (hahaha didnt know your face'll pop up like that)
When I tough I got tired of coming here lurking you just got me going for a f* long time with all those thread I havent see go
Thx !
